[gdal-dev] gdal 2.4.4 with WMS support
aborruso
aborruso at gmail.com
Sun Sep 6 02:35:32 PDT 2020
Hi all,
I have compiled and installed gdal 2.4.4 in this way:
wget http://download.osgeo.org/gdal/2.4.4/gdal244.zip
unzip gdal244.zip
cd ./gdal-2.4.4
./configure --prefix=/usr/local --with-sqlite3=/usr/local
--with-spatialite=/usr/local --with-static-proj4=/usr/local
--with-geos=/usr/local/bin/geos-config
make
sudo make install
But it does not have WMS format and it's impossible to use in example
gdalinfo to have GetCapabilities output. If I run
gdalinfo
"WMS:http://vincoliinrete.beniculturali.it/geoserver/ows?service=wms&version=1.1.1&request=GetCapabilities"
I have
ERROR 4:
WMS:http://vincoliinrete.beniculturali.it/geoserver/ows?service=wms&version=1.1.1&request=GetCapabilities:
No such file or directory
How to compile it to have also WMS support?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
