[gdal-dev] Problem writing with ODS and XLSX drivers
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Sep 12 10:54:25 PDT 2020
Hi Hernán,
I would also set CPL_DEBUG=ON at the commandline, before executing
ogr2ogr. You should see some useful output messages.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-09-12 12:20 p.m., Hernán De Angelis wrote:
> Hi everyone
> I am experiencing an odd and stubborn problem when trying to export
> attribute tables from both shp and spatialite to ods or xlsx. ogr2ogr
> finishes work silently with no reported errors but the generated output
> files cannot be opened with Libreoffice, which says the file is
> corrupted and is even unable to repair it.
> The input files are good from what I can see using QGIS and OGR but it
> is clear that something isn't right in my installation, my procedure or
> somewhere else. I am missing something? Have other users experienced this?
> I am using GDAL/OGR 3.1.2 in openSUSE Tumbleweed, compiled against expat
> 2.2.9-1.12 (devel packages installed too, of course).
> Any hint is appreciated!
> Hernán
