[gdal-dev] Confusion regarding GeoPDF composition.xml units
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Sep 23 05:04:22 PDT 2020
I was remembering that I got involved in user units sometimes and found this
https://trac.osgeo.org/gdal/ticket/5412. Then we considered that PDF is not
valid if user units are not set and if the document is larger than
14400x14400 units. I believe I was playing with orthophoto coverages and
managed to create PDF files that could not be showed with Acrobat but that
was 7 years ago.
-Jukka Rahkonen-
Nyall Dawson wrote
> Ok thanks! I can confirm that removing the writing of user units fixes
> the problem.
> PR opened at https://github.com/OSGeo/gdal/pull/2961
> Nyall
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
