[gdal-dev] OGR C++ API to load Esri JSON
Michal Schneider
schneider.michal at gmail.com
Thu Sep 24 00:59:28 PDT 2020
Hi Mateusz,
thank you for your response and for your time.
I found it in documentation, but I can't see
OGR_G_CreateGeometryFromEsriJson definition in *ogr_api.h* (version 3.0.4,
installed using OSGeo4W).
Something like this, but for OGR_G_CreateGeometryFromEsriJson:
OGRGeometryH CPL_DLL OGR_G_CreateGeometryFromJson( const char* )
CPL_WARN_UNUSED_RESULT;
Best regards,
Michal
On Wed, Sep 23, 2020 at 7:08 PM Mateusz Loskot <mateusz at loskot.net> wrote:
> On Wed, 23 Sep 2020 at 14:48, Michal Schneider
> <schneider.michal at gmail.com> wrote:
> > I see OGR_G_CreateGeometryFromJson in ogr_api.h,
> > but can't see OGR_G_CreateGeometryFromEsriJson there...
> https://gdal.org/api/vector_c_api.html#_CPPv432OGR_G_CreateGeometryFromEsriJsonPKc
> IOW, in first 10 links from the search result set of
> https://gdal.org/search.html?q=ESRI
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200924/e0bcd049/attachment.html>
