[gdal-dev] OGR C++ API to load Esri JSON
Even Rouault even.rouault at spatialys.com
Thu Sep 24 01:32:16 PDT 2020
On jeudi 24 septembre 2020 09:59:28 CEST Michal Schneider wrote:
> Hi Mateusz,
> thank you for your response and for your time.
> I found it in documentation, but I can't see
> OGR_G_CreateGeometryFromEsriJson definition in *ogr_api.h* (version 3.0.4,
> installed using OSGeo4W).
It has been added in GDAL 3.1
You can use the gdal-dev package from OSGeo4W to get it
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200924/d18569b0/attachment.html>
