[gdal-dev] OGR C++ API to load Esri JSON
Michal Schneider
schneider.michal at gmail.com
Thu Sep 24 02:14:44 PDT 2020
Hi Even,
thanks a lot, I will check it.
Best regards,
Michal
On Thu, Sep 24, 2020 at 10:32 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 24 septembre 2020 09:59:28 CEST Michal Schneider wrote:
> > Hi Mateusz,
> > thank you for your response and for your time.
> > I found it in documentation, but I can't see
> > OGR_G_CreateGeometryFromEsriJson definition in *ogr_api.h* (version
> 3.0.4,
> > installed using OSGeo4W).
> It has been added in GDAL 3.1
> You can use the gdal-dev package from OSGeo4W to get it
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200924/91149d20/attachment.html>
