[gdal-dev] ogr2ogr fails on second call with sql select (Paul Higgins)
Paul Higgins
phigginsca at yahoo.com
Fri Sep 25 20:55:59 PDT 2020
I found that the only way around this is to make each call, that has a SELECT in it, to my ogr2ogr function in a separate thread. If there are no SELECTs in the calls then I can make them all in one thread.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200926/fa549af6/attachment.html>
