[gdal-dev] Using GDALRPCTransform with a pre-loaded DEM
Mon Sep 28 05:53:22 PDT 2020
Julien,
The least disruptive approach to this would be for you to store your DEM in
a "memory dataset" and reference that.  I've done this in the past when I
had it in a numpy array by using the numpy driver.  The "MEM" dataset can
be used to reference approximately arbitrary in-memory arrays.
Best regards,
Frank
On Mon, Sep 28, 2020 at 8:21 AM Julien Osman <julien.osman at csgroup.eu>
wrote:
> Dear GDAL community,
> I use the RPC transformer available in GDAL (GDALCreateRPCTransformer
> and GDALRPCTransform).
> To provide a DEM to the transformer, one needs to set the option
> "RPC_DEM" with the path to the DEM file. In my workflow, this is not
> very convenient because the DEM is already loaded in memory as a
> GDALDataset. This means that I need to write it to the disk and let
> GDALCreateRPCTransformer load it again. In my opinion, it would make
> sens to open a little the API so one can provide the DEM directly as a
> GDALDataset.
> If this is OK for you, I can implement this functionality and propose a
> Pull Request. The solution I see would be to add a function
> GDALRPCAddDEM, similar to GDALRPCOpenDEM without the part opening the
> GDALDataset. What do you think?
> Best regards.
> Julien Osman.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
light and sound - activate the windows | +1 650-701-7823
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200928/3586548e/attachment.html>
