[gdal-dev] How does it work FEATURE_SERVER_PAGING?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Sep 30 07:18:09 PDT 2020
I get more features with your command. I tested with GDAL 3.2.0dev
Layer name: out
Geometry: Polygon
Feature Count: 1319
Word "file" in your command is remaining from some copy-paste, I guess.
Using either FEATURE_SERVER_PAGING="YES" or FEATURE_SERVER_PAGING=YES did
not have an effect. Perhaps something truncates your command before the open
option.
-Jukka Rahkonen-
aborruso wrote
> Hi,
> when I try to download some data from the below GeoServices REST server, I
> have always 1000 items, also if I set FEATURE_SERVER_PAGING to YES.
> The command I use is:
> ogr2ogr out.geojson -f GEOJson
> "http://sifweb.regione.sicilia.it/arcgis/rest/services/SIF_INCENDI_EXTENDED/MapServer/13/query?where=objectid>0&outfields=*&f=geojson"
> file -oo FEATURE_SERVER_PAGING="YES"
> If I open it in QGIS, it scrolls through results and I have all the items.
> Is there no direct way to do it in GDAL/OGR?
> I know I can build a 1000 steps for loop, but probably there is something
> wrong in my command or something that I do now know.
> Thank you
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
