[gdal-dev] gdal-dev Digest, Vol 203, Issue 15
Elena Ruiz
eruiz at aplitop.com
Thu Apr 8 03:33:36 PDT 2021
Thank Daniele, I have tried your recommendations, and now works... I had tried hundreds of examples of web services that included the empty fields of the user and password, and they worked perfectly, but from what it seems this service does not support it, thank you very much again
-----Mensaje original-----
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de gdal-dev-request at lists.osgeo.org
Enviado el: jueves, 8 de abril de 2021 12:24
Para: gdal-dev at lists.osgeo.org
Asunto: gdal-dev Digest, Vol 203, Issue 15
Send gdal-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
gdal-dev-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of gdal-dev digest..."
Today's Topics:
1. Re: HTTP 401 error with WMS (Daniele Romagnoli)
Message: 1
Date: Thu, 8 Apr 2021 12:23:49 +0200
From: Daniele Romagnoli <daniele.romagnoli at geo-solutions.it>
To: Elena Ruiz <eruiz at aplitop.com>
Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] HTTP 401 error with WMS
Message-ID:
<CAJaHrDzbgtd-kq+eL2uQBy7X+fkFHM=UZ0R6U1_fN1ZyLhdp9A at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hello Elena,
the error messages report "Unauthorized".
I would try by modifying the ServerlUrl, removing the user and password empty parameters, so that it just contains the base WMS url:
<ServerUrl>https://wms.mapa.gob.es/sigpac/ows?SERVICE=WMS</ServerUrl>
and also removing the <UserPwd>:</UserPwd> tag at the bottom of your xml.
Let us know if that works.
Regards,
Daniele
On Thu, Apr 8, 2021 at 10:51 AM Elena Ruiz <eruiz at aplitop.com> wrote:
> Hello, I trying a WMS web service with gdal, but I have different
> results depend on I use a url in a web browser or I use the gdal commands.
> If I put this url in Crome:
> https://wms.mapa.gob.es/sigpac/ows?FORMAT=image/jpeg&HEIGHT=99&LAYERS=
> EEPP&WIDTH=183&SERVICE=WMS&BBOX=413276.0389803443,4066482.0439935336,6
> 75346.7028941214,4208125.2305295570&REQUEST=GetMap&TRANSPARENT=FALSE&S
> TYLES=&VERSION=1.3.0&CRS=EPSG:25830
> I get an image:
> But If I use the same parameters in a XML file, like as this:
> <GDAL_WMS>
> <Service name="WMS">
> <Version>1.3.0</Version>
> <ServerUrl>
> https://wms.mapa.gob.es/sigpac/ows?SERVICE=WMS&username=&passw
> ord=
> </ServerUrl>
> <Layers>EEPP</Layers>
> <CRS>EPSG:25830</CRS>
> <ImageFormat>image/jpeg</ImageFormat>
> <Transparent>FALSE</Transparent>
> <BBoxOrder>xyXY</BBoxOrder>
> </Service>
> <DataWindow>
> <UpperLeftX>413276.0389803443</UpperLeftX>
> <UpperLeftY>4208125.2305295570</UpperLeftY>
> <LowerRightX>675346.7028941214</LowerRightX>
> <LowerRightY>4066482.0439935336</LowerRightY>
> <SizeX>183</SizeX>
> <SizeY>99</SizeY>
> </DataWindow>
> <Timeout>1600</Timeout>
> <BandsCount>3</BandsCount>
> <BlockSizeX>1024</BlockSizeX>
> <BlockSizeY>1024</BlockSizeY>
> <OverviewCount>20</OverviewCount>
> <UnsafeSSL>true</UnsafeSSL>
> <ZeroBlockHttpCodes></ZeroBlockHttpCodes>
> </GDAL_WMS>
> And then I run the next gdal command: gdal_translate -of JPEG -outsize
> 183
> 99 C:\Users\elena\AppData\Local\Temp\tmpnuevo.xml
> C:\Users\elena\AppData\Local\Temp\miimagen.jpeg
> The result is :
> Input file size is 183, 99
> 0ERROR 1: GDALWMS: Unable to download block 0, 0.
> URL: <!doctype html><html lang="es"><head><title>Estado HTTP 401 ???
> No autorizado</title><style type="text/css">body
> {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b
> {color:white;background-color:#525D76;} h1 {font-size:22px;} h2
> {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a
> {color:black;} .line
> {height:1px;background-color:#525D76;border:none;}</style></head><body
> ><h1>Estado HTTP 401 ??? No autorizado</h1><hr class="line"
> /><p><b>Tipo</b> Informe de estado</p><p><b>mensaje</b>
> Unauthorized</p><p><b>Descripci??n</b> Este requerimiento requiere
> autenticaci??n HTTP.</p><hr class="line"
> /><h3>Apache Tomcat/9.0.37</h3></body></html>
> HTTP status code: 401, error: <!doctype html><html
> lang="es"><head><title>Estado HTTP 401 ??? No autorizado</title><style
> type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2,
> h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2
> /><h3>Apache Tomcat/9.0.37</h3></body></html>.
> Add the HTTP status code to <ZeroBlockHttpCodes> to ignore this error
> (see http://www.gdal.org/frmt_wms.html).
> ERROR 1: C:\Users\elena\AppData\Local\Temp\tmpnuevo.xml, band 1:
> IReadBlock failed at X offset 0, Y offset 0: GDALWMS: Unable to
> And there are not any image.
> I?m using gdal 3.0, and I don?t understand why works at web browser
> and don?t works with gdal, I am doing something wrong? Thank you very
> much and regards
> *Elena Ruiz *
> Sofware Development & Technical Support Tel. +34 952 43 97 71
> eruiz at aplitop.com Sumatra, 9 - 29190 M?laga (Spain)
> *www.aplitop.com <http://www.aplitop.com>
> <https://www.facebook.com/AplitopSL/> <https://twitter.com/aplitop>
> <https://www.linkedin.com/company/aplitop>
> <https://www.youtube.com/user/aplitop>*
> In accordance with the provisions of the European Regulation of Data
> Protection 2016/679 (Reglamento Europeo de Protecci?n de Datos
> 2016/679), we inform you that the data and the information you provide
> us through this medium will be used by APLITOP, S.L., with C.I.F.
> B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order
> to answer your questions and inform you about our products. The data
> provided will be kept as long as it does not request its cessation and
> will not be transferred to third parties except in cases where there
> is a legal obligation. You have the right to access your personal
> data, correct inaccurate data or request its deletion when the data is
> no longer necessary for the purposes that were collected, as well as
> any rights recognized in the RGPD 2016/679
> <https://www.aplitop.com/Event/en/358/intergeo-2019>
Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati ?GDPR?), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) ? un dato la cui conoscenza ?
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le ? giunto per errore, ? tenuta/o a cancellarlo, ogni altra operazione ? illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 ?GDPR? - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/76f1766e/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/76f1766e/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/76f1766e/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/76f1766e/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/76f1766e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/76f1766e/attachment-0003.png>
Subject: Digest Footer
End of gdal-dev Digest, Vol 203, Issue 15
