[gdal-dev] "gdalbuildvrt does not support rotated geo transforms"
Lorenzo Di Giacomo
loridigia at gmail.com
Thu Apr 8 04:31:58 PDT 2021
Hi, do you know why this happens when i try to merge tiles of a specific
tiff?
How can check if a tiff had a rotated geo transforms? And how can i fix it
before merging it?
Here are some QGIS info about the tiff:
SR EPSG:4326 - WGS 84 - Geografico
Estensione -179.9999999999999716,-90.0040001037068436 :
180.0080002074136871,89.9999999999999858
Unità gradi
Larghezza 54000
Altezza 27000
Tipo di dato Byte- intero senza segno di 8 bit
Descrizione Driver GDAL GTiff
Metadato Driver GDAL GeoTIFF
Descrizione dell'insieme di dati
Compressione
Banda 1
- STATISTICS_APPROXIMATE=YES
- STATISTICS_MAXIMUM=255
- STATISTICS_MEAN=5.3210525813876
- STATISTICS_MINIMUM=0
- STATISTICS_STDDEV=18.136379276344
- STATISTICS_VALID_PERCENT=100
Banda 2
- STATISTICS_MEAN=10.134402838017
- STATISTICS_MINIMUM=1
- STATISTICS_STDDEV=17.628760932834
Banda 3
- STATISTICS_MEAN=41.73256634051
- STATISTICS_MINIMUM=28
- STATISTICS_STDDEV=20.687348771707
Maggiori informazioni
Dimensioni X: 54000 Y:.27000 Bande: 3
Origine -180,90
Dimensione pixel
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210408/9604d859/attachment.html>
