[gdal-dev] Registered Content-Type for VRT?
Even Rouault even.rouault at spatialys.com
Tue Apr 20 09:09:41 PDT 2021
application/gdalvrt+xml would just mean what the organization that defines the format is. People could reimplement that from scratch
Note that there is potentially the OGR VRT format (that could go as application/ogrvrt+xml), but that is a separate schema and likely less used than its raster counterpart.
Le 20/04/2021 à 18:04, Sean Gillies via gdal-dev a écrit :
> Hi Jukka,
> It's possible that ArcGIS has independently implemented VRT, but I
> think it's more likely that it delegates to GDAL. I think it would be
> possible to craft a VRT doc that would reveal some details -- such as
> one that uses GDAL's embedded Python pixel functions to dump some
> system information -- but I don't have access to ArcGIS to try it.
> On Mon, Apr 19, 2021 at 4:01 PM jratike80
> <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
>     Hi,
>     Do you count ArcMap or ArcGIS Pro as self standing software or
>     rather as
>     applications that use GDAL? They read VRTs pretty well but for
>     writing some
>     developer tools are required
>     https://pro.arcgis.com/en/pro-app/latest/help/data/imagery/supported-raster-dataset-file-formats.htm
>     <https://pro.arcgis.com/en/pro-app/latest/help/data/imagery/supported-raster-dataset-file-formats.htm>.
>     -Jukka Rahkonen-
>     GDAL - Dev mailing list wrote
>     > Maybe application/gdalvrt+xml? As far as I know, GDAL is the
>     only software
>     > that plays VRTs, and probably the only software that ever can,
>     considering
>     > the extensions and embedded Python stuff.
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210420/d4f413f4/attachment-0001.html>
