[gdal-dev] Accessing a Nitf DES
Even Rouault
even.rouault at spatialys.com
Fri Apr 23 01:24:42 PDT 2021
https://github.com/OSGeo/gdal/pull/3153 should cover this need
Le 23/04/2021 à 02:07, jovajova24 a écrit :
> So I found this issue that never got merged i.e.,
> https://github.com/OSGeo/gdal/pull/2336
> I'm assuming this means that GDAL doesn't support accessing GLAS\GFM DES
> right now? If not, could I finsh this PR?
> Also, can someone point me to any sudo c++ example code in how to access a
> DES?
> Thanks.
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
