[gdal-dev] how to use tiledb datasets on gcs?
Vincent Schut schut at satelligence.com
Fri Apr 23 05:59:12 PDT 2021
On 4/23/21 2:17 PM, Vincent Schut wrote:
> Hi, how should I specify a tiledb dataset's url that resides on gcs
> (google cloud storage) to gdal? I've tried several combinations of
> gcs://, /vsigs/, prefixed with TILEDB:// or not, but no luck. I've
> looked in the driver source, and apparently there is only a /vsis3/ ->
> tiledb uri translation, but no equivalent gcs one?
To clarify this a bit: writing works:
gdal_translate -of tiledb -co COMPRESSION=ZSTD
S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tif
gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb
and the file is correctly created in the bucket. However, when I want to
open it, it fails:
gdalinfo -if tiledb
ERROR 4:
gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb:
No such file or directory
gdalinfo failed - unable to open
'gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb'.
Is there any way to correctly specify this tiledb url on gcs for gdal?
Vincent.
> Vincent Schut
> Remote Sensing Software Engineer
> +31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
> Linkedin <https://www.linkedin.com/company/satelligence/>~
> satelligence.com
> <http://www.satelligence.com><http://www.satelligence.com>
Vincent Schut
satelligence.com <http://www.satelligence.com><http://www.satelligence.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210423/d7a892f6/attachment.html>
