[gdal-dev] how to use tiledb datasets on gcs?
Even Rouault even.rouault at spatialys.com
Fri Apr 23 06:09:16 PDT 2021
I guess you should add something similar to
https://github.com/OSGeo/gdal/commit/3623f9c91a2c513af204d30fe25314dbe5c7b9be
for /vsigs
Le 23/04/2021 à 14:59, Vincent Schut a écrit :
> On 4/23/21 2:17 PM, Vincent Schut wrote:
>> Hi, how should I specify a tiledb dataset's url that resides on gcs
>> (google cloud storage) to gdal? I've tried several combinations of
>> gcs://, /vsigs/, prefixed with TILEDB:// or not, but no luck. I've
>> looked in the driver source, and apparently there is only a /vsis3/
>> -> tiledb uri translation, but no equivalent gcs one?
> To clarify this a bit: writing works:
> gdal_translate -of tiledb -co COMPRESSION=ZSTD
> S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tif
> gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb
> and the file is correctly created in the bucket. However, when I want
> to open it, it fails:
> gdalinfo -if tiledb
> ERROR 4:
> gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb:
> No such file or directory
> gdalinfo failed - unable to open
> 'gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb'.
> Is there any way to correctly specify this tiledb url on gcs for gdal?
> Vincent.
>> Vincent Schut
>> Remote Sensing Software Engineer
>> +31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
>> Linkedin <https://www.linkedin.com/company/satelligence/>~
>> satelligence.com
>> <http://www.satelligence.com><http://www.satelligence.com>
> Vincent Schut
> satelligence.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210423/d33e02b8/attachment-0001.html>
