[gdal-dev] how to use tiledb datasets on gcs?
Vincent Schut
schut at satelligence.com
Fri Apr 23 06:34:17 PDT 2021
Thanks for confirming, Even. That doesn't look too difficult. I'll give
it a try.
On 4/23/21 3:09 PM, Even Rouault wrote:
> I guess you should add something similar to
> https://github.com/OSGeo/gdal/commit/3623f9c91a2c513af204d30fe25314dbe5c7b9be
> for /vsigs
> Le 23/04/2021 à 14:59, Vincent Schut a écrit :
>> On 4/23/21 2:17 PM, Vincent Schut wrote:
>>> Hi, how should I specify a tiledb dataset's url that resides on gcs
>>> (google cloud storage) to gdal? I've tried several combinations of
>>> gcs://, /vsigs/, prefixed with TILEDB:// or not, but no luck. I've
>>> looked in the driver source, and apparently there is only a /vsis3/
>>> -> tiledb uri translation, but no equivalent gcs one?
>> To clarify this a bit: writing works:
>> gdal_translate -of tiledb -co COMPRESSION=ZSTD
>> S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tif
>> gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb
>> and the file is correctly created in the bucket. However, when I want
>> to open it, it fails:
>> gdalinfo -if tiledb
>> ERROR 4:
>> gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb:
>> No such file or directory
>> gdalinfo failed - unable to open
>> 'gcs://s11-dev-vincent-tiledb-test-public/S2B_MSIL1C_20210227T032659_N0209_R018_T47MQV_20210227T072433.tiledb'.
>> Is there any way to correctly specify this tiledb url on gcs for gdal?
>> Vincent.
>>> Vincent Schut
>>> Remote Sensing Software Engineer
>>> +31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
>>> Linkedin <https://www.linkedin.com/company/satelligence/>~
>>> satelligence.com
>>> <http://www.satelligence.com><http://www.satelligence.com>
>> Vincent Schut
>> satelligence.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
Vincent Schut
satelligence.com <http://www.satelligence.com><http://www.satelligence.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210423/6064ec70/attachment.html>
