[gdal-dev] Nitf Metadata parsing
jovajova24 ejovenitti at gmail.com
Sun Apr 25 10:52:44 PDT 2021
I found this,
http://osgeo-org.1560.x6.nabble.com/gdal-dev-NITF-DES-Data-td5448580.html (
and other threads) -- so it sounds like to parse a NITF DES you need to
rebuild GDAl with the ESRI_BUILD flag. Is this correct ?
Mover-over, I've been trying to find some c++ sample code to parse a NITF
DES.
Via this thread:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Accessing-a-Nitf-DES-td5485537.html
Even pointed me to this link:
https://github.com/OSGeo/gdal/pull/3153  ( and thank you for that) but these
examples use objects like:
 NITFSegmentInfo
 NITFDESGetXml
Which when you download 3.2.1 for Windows, none of these specific NITF
objects
are included in the compilation.
Ok DUMB question (and I apologize for this) how do you get access to the
listed above nitf specific objects?
Is there a way to parse NITF DES data without using these objects?
So, now I'm trying to build GDAL myself and I run into the following issue:
On VS 2019 it's complaining about the correct version of PROJ >= 6, even
though I've set it to version 7.2.
Can any one build the latest GDAL on windows outside the CI loop?
If so can you post your setup?
Thanks again.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
