[gdal-dev] Nitf Metadata parsing
Brad Hards
bradh at frogmouth.net
Sun Apr 25 20:37:38 PDT 2021
I'm not sure what you mean by "objects" in this context. Do you mean methods and structures?
It seems like you are referring to a lot of older mailing list threads. It is probably better to read the code.
For the DES case, you can see how GDAL does it through gdalinfo, with a command like:
./apps/gdalinfo -mdd xml:DES ~/20200723-RIP1B_BIP_Final_Released/07APR2005_Hyperion_331406N0442000E_SWIR172_001_L1R-01B-BIP-GLAS.ntf
Which produces:
Driver: NITF/National Imagery Transmission Format
Files: /home/bradh/20200723-RIP1B_BIP_Final_Released/07APR2005_Hyperion_331406N0442000E_SWIR172_001_L1R-01B-BIP-GLAS.ntf
Size is 64, 838
Coordinate System is:
GEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ID["EPSG",4326]]
Data axis to CRS axis mapping: 2,1
GeoTransform =
44.41283704082986, 0.001278659611993035, -0.0002860746050710144
33.69168768134494, -0.0002182539682539298, -0.001073775388291513
Metadata:
NITF_ABPP=08
NITF_CCS_COLUMN=0
NITF_CCS_ROW=0
NITF_CLEVEL=05
NITF_ENCRYP=0
NITF_FBKGC= 0, 0, 0
NITF_FDT=20200723130601
NITF_FHDR=NITF02.10
NITF_FSCATP=
NITF_FSCAUT=
NITF_FSCLAS=U
NITF_FSCLSY=
NITF_FSCLTX=
NITF_FSCODE=
NITF_FSCOP=00000
NITF_FSCPYS=00000
NITF_PVTYPE=INT
NITF_STYPE=BF01
NITF_TGTID=
Metadata (xml:DES):
<des_list>
<des name="CSEPHB">
<field name="NITF_DESVER" value="01" />
<field name="NITF_DECLAS" value="U" />
<field name="NITF_DESCLSY" value="" />
<field name="NITF_DESCODE" value="" />
<field name="NITF_DESCTLH" value="" />
<field name="NITF_DESREL" value="" />
<field name="NITF_DESDCTP" value="" />
<field name="NITF_DESDCDT" value="" />
<field name="NITF_DESDCXM" value="" />
<field name="NITF_DESDG" value="" />
<field name="NITF_DESDGDT" value="" />
<field name="NITF_DESCLTX" value="" />
<field name="NITF_DESCATP" value="" />
<field name="NITF_DESCAUT" value="" />
<field name="NITF_DESCRSN" value="" />
<field name="NITF_DESSRDT" value="" />
<field name="NITF_DESCTLN" value="" />
<field name="NITF_DESSHL" value="0085" />
<field name="NITF_DESSHF" value="cf306a0b-c47c-44fa-af63-463549f6bf98001002001824ecf8e-1041-4cce-9edb-bc92d88624ca0000" />
<field name="NITF_DESDATA"
value="MTI1MDEwMDEuMDAwMDAwMDAwMjAwNTA0MDcwNzI0MDUuODg5MDAwMDAwMDAwMjQrMDQxNDg0NDQuMjUrMDQxODIwMDkuODQrMDM5MjM1NzMuODcrMDQxNTI1NTQuN
TMrMDQxODM3MTQuMzMrMDM5MTc0MjIuNjYrMDQxNTY2NjAuMzMrMDQxODU0MTMuNTErMDM5MTEyNjYuOTUrMDQxNjA3NjEuNzIrMDQxODcxMDcuNDkrMDM5MDUxMDYuOTMrM
DQxNjQ4NTguNzErMDQxODg3OTYuMTgrMDM4OTg5NDIuNDMrMDQxNjg5NTEuMjkrMDQxOTA0NzkuNTcrMDM4OTI3NzMuNjErMDQxNzMwMzkuNDgrMDQxOTIxNTcuNjYrMDM4O
DY2MDAuNDArMDQxNzcxMjMuMjcrMDQxOTM4MzAuNDQrMDM4ODA0MjIuNzgrMDQxODEyMDIuNTcrMDQxOTU0OTguMDIrMDM4NzQyNDAuODcrMDQxODUyNzcuNDYrMDQxOTcxN
jAuMzIrMDM4NjgwNTQuNDYrMDQxODkzNDcuOTUrMDQxOTg4MTcuMjErMDM4NjE4NjMuODMrMDQxOTM0MTMuOTUrMDQyMDA0NjguODkrMDM4NTU2NjguNzMrMDQxOTc0NzUuN
TQrMDQyMDIxMTUuMjgrMDM4NDk0NjkuMzArMDQyMDE1MzIuNjQrMDQyMDM3NTYuMzcrMDM4NDMyNjUuNTgrMDQyMDU1ODUuMzMrMDQyMDUzOTIuMTUrMDM4MzcwNTcuNTYrM
DQyMDk2MzMuNTMrMDQyMDcwMjIuNzMrMDM4MzA4NDUuMTQrMDQyMTM2NzcuMjIrMDQyMDg2NDcuOTMrMDM4MjQ2MjguNTErMDQyMTc3MTYuNTIrMDQyMTAyNjcuODErMDM4M
Tg0MDcuNTArMDQyMjE3NTEuMjIrMDQyMTE4ODIuNTArMDM4MTIxODIuMTgrMDQyMjU3ODEuNTErMDQyMTM0OTEuODArMDM4MDU5NTIuNTUrMDQyMjk4MDcuMzErMDQyMTUwO
TUuNzgrMDM3OTk3MTguNzIrMDQyMzM4MjguNjErMDQyMTY2OTQuNTYrMDM3OTM0ODAuNTErMDQyMzc4NDUuNDErMDQyMTgyODcuOTYrMDM3ODcyMzguMDcrMDQyNDE4NTcuN
zIrMDQyMTk4NzYuMDQrMDM3ODA5OTEuMzUwMDAwMDAwMDA=" />
</des>
<des name="CSCSDB">
Clearly you'll need to parse out the DESDATA part of the segment, using STDI-0002 as a guide.
Brad
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of jovajova24
Sent: Monday, 26 April 2021 3:53 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Nitf Metadata parsing
I found this,
http://osgeo-org.1560.x6.nabble.com/gdal-dev-NITF-DES-Data-td5448580.html ( and other threads) -- so it sounds like to parse a NITF
DES you need to rebuild GDAl with the ESRI_BUILD flag. Is this correct ?
Mover-over, I've been trying to find some c++ sample code to parse a NITF DES.
Via this thread:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Accessing-a-Nitf-DES-td5485537.html
Even pointed me to this link:
https://github.com/OSGeo/gdal/pull/3153 ( and thank you for that) but these examples use objects like:
NITFSegmentInfo
NITFDESGetXml
Which when you download 3.2.1 for Windows, none of these specific NITF objects are included in the compilation.
Ok DUMB question (and I apologize for this) how do you get access to the listed above nitf specific objects?
Is there a way to parse NITF DES data without using these objects?
So, now I'm trying to build GDAL myself and I run into the following issue:
On VS 2019 it's complaining about the correct version of PROJ >= 6, even though I've set it to version 7.2.
Can any one build the latest GDAL on windows outside the CI loop?
If so can you post your setup?
Thanks again.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
