[gdal-dev] Nitf Metadata parsing
jovajova24
ejovenitti at gmail.com
Mon Apr 26 11:45:20 PDT 2021
Brad,
Thanks for the reply!
The objects I'm referring to are what I have listed i.e.,
NITFSegmentInfo
NITFDESGetXml
These objects were changed in the PR I have listed i.e.,
https://github.com/OSGeo/gdal/pull/3153/files#diff-084e5d55477ff6b3acacb5bf240281a52d778c07106fb1fb2b53f1275988a25eR2476-R2488
This PR (PR 3153) was merged in Nov 6 2020 so it does not appear to be old
code.
But, none of these Nitf specific objects are in any releases and I don't
understand why. The include/frmt directory is where they are in the source
code, but I can never find include/frmt in any Windows build.
Can I ask what makes you think it's old code?
Also did you create that output with a GDAL build that has the ESRI_NITF
flag set?
Thanks again!
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
