[gdal-dev] Test Data
Andrew Bell
andrew.bell.ia at gmail.com
Mon Apr 26 07:12:41 PDT 2021
I'm trying to run autotests and am failing to find data. For instance, I
get the error:
def test_ogr_arcgen_points():
ds = ogr.Open('data/arcgen/points.gen')
> assert ds is not None, 'cannot open dataset'
E AssertionError: cannot open dataset
E assert None is not None
I see that this file is in the directory autotest/ogr/data/arcgen
I tried including this directory in GDAL_DATA, but the error persists. My
command line is:
DYLD_LIBRARY_PATH=../gdal/.libs
PYTHONPATH=/Users/acbell/gdal/gdal/swig/python/build/lib.macosx-10.9-x86_64-3.9
GDAL_DATA=../gdal/data:./ogr pytest ogr/ogr_arcgen.py
Does anyone have information on how to I might resolve this?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210426/7c87c97d/attachment.html>
