[gdal-dev] Test Data
Even Rouault
even.rouault at spatialys.com
Mon Apr 26 07:18:13 PDT 2021
Andrew,
you don't need to add autotest/ogr to GDAL_DATA.
ARCGEN is now a deprecated driver and must be explictly enabled with
GDAL_ENABLE_DEPRECATED_DRIVER_ARCGEN=YES env variable.
Normally this is done in autotest/pytest.ini
I suspect you don't have the pytest-env python module installed.
You should probably just run:
pip3 install -U -r autotest/requirements.txt
which will install it
Even
Le 26/04/2021 à 16:12, Andrew Bell a écrit :
> Hi,
> I'm trying to run autotests and am failing to find data. For instance,
> I get the error:
> def test_ogr_arcgen_points():
> ds = ogr.Open('data/arcgen/points.gen')
> > assert ds is not None, 'cannot open dataset'
> E AssertionError: cannot open dataset
> E assert None is not None
> I see that this file is in the directory autotest/ogr/data/arcgen
> I tried including this directory in GDAL_DATA, but the error persists.
> My command line is:
> DYLD_LIBRARY_PATH=../gdal/.libs
> PYTHONPATH=/Users/acbell/gdal/gdal/swig/python/build/lib.macosx-10.9-x86_64-3.9
> GDAL_DATA=../gdal/data:./ogr pytest ogr/ogr_arcgen.py
> Does anyone have information on how to I might resolve this?
> Thanks,
> Andrew Bell
> andrew.bell.ia at gmail.com <mailto:andrew.bell.ia at gmail.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210426/d23f9ff7/attachment.html>
