[gdal-dev] Nitf Metadata parsing
Eric Jovenitti ejovenitti at gmail.com
Mon Apr 26 21:10:37 PDT 2021
On Tue, Apr 27, 2021 at 12:08 AM <bradh at frogmouth.net> wrote:
> Ok. Have a nice day.
> On 27 Apr. 2021 04:45, jovajova24 <ejovenitti at gmail.com> wrote:
> Brad,
> Thanks for the reply!
> The objects I'm referring to are what I have listed i.e.,
>  NITFSegmentInfo
>  NITFDESGetXml
> These objects were changed in the PR I have listed i.e.,
> https://github.com/OSGeo/gdal/pull/3153/files#diff-084e5d55477ff6b3acacb5bf240281a52d778c07106fb1fb2b53f1275988a25eR2476-R2488
> This PR (PR 3153) was merged in Nov 6 2020 so it does not appear to be old
> code.
> But, none of these Nitf specific objects are in any releases and I don't
> understand why. The include/frmt directory is where they are in the source
> code, but I can never find include/frmt in any Windows build.
> Can I ask what makes you think it's old code?
> Also did you create that output with a GDAL build that has the ESRI_NITF
> flag set?
> Thanks again!
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210427/b161e175/attachment-0001.html>
