[gdal-dev] Nitf Metadata parsing
jovajova24 ejovenitti at gmail.com
Tue Apr 27 18:01:53 PDT 2021
Brad, sorry for pushing but I'm going in circles here. It looks like you and
Even had this discussion i.e.,
http://osgeo-org.1560.x6.nabble.com/gdal-dev-Accessing-DES-in-NITF-through-GDAL-td5434141.html
You gave me the example of how to output the DES's  from the command line,
but the builds I'm pulling can't actually get access to the DES data on
Windows.
Was your build that you showed the output from above complied with the
ESRI_NITF flagged as Even suggested?
If yes, I can't figure out how to set the ESRI_NITF build flagged, any
thoughts?
Thanks again.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
