[gdal-dev] Test Failures
Andrew Bell andrew.bell.ia at gmail.com
Tue Apr 27 11:49:39 PDT 2021
On Tue, Apr 27, 2021 at 2:27 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Andrew,
> This could be due to the PROJ version, but as I'm running with 8.0 too
> (and one of the CI config runs PROJ master), I suspect you just need to
> install the "conus" grid for NAD27 to WGS84 transformations into
> {proj_prefix}/share/proj . Unpack
> http://download.osgeo.org/proj/proj-datumgrid-1.8.tar.gz
I have PROJ_NETWORK set to ON. I was under the impression that this would
cause PROJ to find whatever grids shift files it needed at runtime. Is
there more configuration that's necessary to get this to happen or do I
misunderstand the PROJ_NETWORK setting?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210427/5da3bc5f/attachment.html>
