[gdal-dev] PROJ context and threads
Andrew Bell
andrew.bell.ia at gmail.com
Tue Apr 27 18:30:00 PDT 2021
I have a process with a large thread pool. The threads occasionally make a
GDAL call that in turn calls a PROJ function. From what I can tell, this
causes the opening of a PROJ context that holds a handle/descriptor to the
PROJ database. I believe that this file descriptor is held open in TLS
until the thread is destroyed. This ends up keeping enough files open for
my application that I run out of file descriptors.
Am I properly understanding the PROJ context behavior? Is there any way to
force the deallocation of the PROJ context so that the file descriptor for
the database can be closed?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210427/ef437743/attachment.html>
