[gdal-dev] PROJ context and threads
Alan Snow
alansnow21 at gmail.com
Tue Apr 27 20:35:43 PDT 2021
You are correct. Here is the related issue:
https://github.com/OSGeo/PROJ/issues/1565
The solution would be to use proj_context_set_autoclose_database. This can
reduce performance for single threaded applications, so it would probably
be good to have a way to toggle it on for multi-threaded applications.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210427/909d7eb8/attachment.html>
