[gdal-dev] ODBC and configure
Greg Troxel
gdt at lexort.com
Thu Apr 29 05:53:20 PDT 2021
I have a report from a pkgsrc user of the ODBC library being missing
from gdal.so. pkgsrc doesn't declare a dependency so this is intended
to be hidden from the build evironment.
I went looking for docs and found:
https://gdal.org/drivers/vector/odbc.html
which says
ODBC support is potentially available on Unix and Windows platforms,
but is only included in unix builds by special configuration options.
however when I build gdal I see in the output:
check for unixODBC
checking for SQLConnect in -lodbc... no
which makes it look like the build is looking for ODBC in the build
environment even though it was not explicitly requested. Reading
configure.ac, it's clear that absent --without-odbc, ODBC libs are
looked for and used if found.
So I'm not sure if this is a build bug or a doc bug.
Either way, I'll just add --without-odbc.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210429/23bed0fc/attachment.sig>
