[gdal-dev] Degree symbols
Andrew C Aitchison andrew at aitchison.me.uk
Thu Apr 29 06:44:25 PDT 2021
Now that PROJ data includes "AREA" descriptions with degree symbols,
what to people think about the attached patch which makes CPLDecToDMS
report angles with the degree symbol too ?
Sadly, the reverse function CPLDMSToDec will need more work as we
cannot fudge the fact that the degree symbol is a wchar there.
----- Sample output from
-----     gdalinfo ./swig/java/test_data/byte.tif
Driver: GTiff/GeoTIFF
Files: ./swig/java/test_data/byte.tif
Size is 20, 20
Coordinate System is:
PROJCRS["NAD27 / UTM zone 11N",
     BASEGEOGCRS["NAD27",
     USAGE[
         SCOPE["Engineering survey, topographic mapping."],
         AREA["North America - between 120°W and 114°W - onshore. Canada - Alberta; British Columbia; Northwest Territories; Nunavut. Mexico. United States (USA) - California; Idaho; Nevada; Oregon; Washington."],
         BBOX[26.93,-120,78.13,-114]],
     ID["EPSG",26711]]
Data axis to CRS axis mapping: 1,2
Origin = (440720.000000000000000,3751320.000000000000000)
Pixel Size = (60.000000000000000,-60.000000000000000)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  440720.000, 3751320.000) (117°38'28.21"W, 33°54' 8.47"N)
Lower Left  (  440720.000, 3750120.000) (117°38'27.92"W, 33°53'29.51"N)
Upper Right (  441920.000, 3751320.000) (117°37'41.48"W, 33°54' 8.71"N)
Lower Right (  441920.000, 3750120.000) (117°37'41.20"W, 33°53'29.75"N)
Center      (  441320.000, 3750720.000) (117°38' 4.70"W, 33°53'49.11"N)
Band 1 Block=20x20 Type=Byte, ColorInterp=Gray
Andrew C. Aitchison					Kendal, UK
Type: text/x-diff
Desc:
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210429/64717124/attachment.patch>
