[gdal-dev] unicode support in GDAL
Even Rouault
even.rouault at spatialys.com
Thu Aug 12 09:23:48 PDT 2021
Claudiu,
OGR supports unicode strings, and expect/outputs in UTF-8 as the pivot
encoding. See https://gdal.org/development/rfc/rfc23_ogr_unicode.html
for details
For shapefiles on writing, you'll need to pass the ENCODING=UTF-8 layer
creation option (see
https://gdal.org/drivers/vector/shapefile.html#layer-creation-options),
or at another value that is compatible of cyrillic characters (CP1251 e.g.)
Demo (in UTF-8 console)
$ cat cyrillic.csv
id,txt
1,"Привет"
$ ogr2ogr cyrillic.shp cyrillic.csv -lco ENCODING=CP1251
$ ogrinfo cyrillic.dbf -al -q
Layer name: cyrillic
Metadata:
DBF_DATE_LAST_UPDATE=2021-08-12
OGRFeature(cyrillic):0
id (String) = 1
txt (String) = Привет
Even
Le 12/08/2021 à 17:54, Claudiu Cochior via gdal-dev a écrit :
> Hello everybody,
> I have a question related to Unicode strings in GDAL
> We are using GDAL 3.0.4 and at some point we would like to write to
> shapefile a string that contains Russian characters. To give you some
> context, we are in C++, we created a OGRFeature and we want to set a
> field to the string that contains the Russian characters. My machine
> is in English and the language for non-unicode programs is set to
> English. I didn’t find in the GDAL doc a definitive answer if GDAL
> support Unicode strings for filed values. As a test I converted the
> System::String to UTF-8 but the shape file displays only ? for the
> characters. If I change the language for non-unicode programs to
> Russian then I can safely extract the ANSI string and give it to the
> SetField method and the result is OK.
> So, does GDAL supports unicede field string values somehow?
> Thanks,
> Claudiu
> This email, including any attachments, may contain confidential and/or
> proprietary information intended only for the use of the recipient. If
> you are not the intended recipient, any distribution, copying, or use
> of this email or its attachments is prohibited. If you received this
> email in error, please reply to the sender immediately and delete this
> message and any copies.
> /Bentley Systems has taken all reasonable steps to ensure that this
> communication is free from viruses, data corruption, and unauthorized
> alteration. Bentley Systems does not accept liability for any damages
> that may be incurred as a result of this or any communication by email/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210812/54033e40/attachment-0001.html>
