[gdal-dev] Convert OGRGeometry* to pointer to derived geometry type
Brook Milligan
brook at nmsu.edu
Fri Aug 13 17:23:51 PDT 2021
I would like to convert a pointer to OGRGeometry into a pointer to the appropriate derived type based upon the result of wkbFlatten(geometry->getGeometryType()). It used to be possible to do this with functions like geometry->toLineString(). However, it seems that those are all deleted with the OGR_FORBID_DOWNCAST_TO(name) macro, although the functions are listed in the API documentation.
How is this conversion supposed to be accomplished now?
Thanks for any pointers.
Cheers,
Brook
