[gdal-dev] Convert OGRGeometry* to pointer to derived geometry type
Even Rouault
even.rouault at spatialys.com
Sat Aug 14 05:30:48 PDT 2021
Brook,
toXXXX methods can still be used. We just have restricted invalid
conversions, like a LineString to Polygon
A great part of what is valid is tested in
https://github.com/OSGeo/gdal/blob/1ec0b63d8820b2d3f0cfb792e05f3f5fea49892c/autotest/cpp/test_ogr.cpp#L787
Even
Le 14/08/2021 à 02:23, Brook Milligan a écrit :
> I would like to convert a pointer to OGRGeometry into a pointer to the appropriate derived type based upon the result of wkbFlatten(geometry->getGeometryType()). It used to be possible to do this with functions like geometry->toLineString(). However, it seems that those are all deleted with the OGR_FORBID_DOWNCAST_TO(name) macro, although the functions are listed in the API documentation.
> How is this conversion supposed to be accomplished now?
> Thanks for any pointers.
> Cheers,
> Brook
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
