[gdal-dev] Puzzled about gdal_translate return all white image...
Carl Godkin
cgodkin at gmail.com
Fri Aug 20 18:36:07 PDT 2021
I'm very puzzled about why gdal_translate (v. 3.3.1) returns an all-white
image when I select a smaller area than with a working case with a larger
area.
These two command lines are exactly the same except that the failing case
has a smaller area:
gdal_translate "
https://basemap.nationalmap.gov:443/arcgis/services/USGSImageryTopo/MapServer/WmsServer?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=0&SRS=EPSG:4326&BBOX=-179.999989,-89.000000,179.999988,89.000000"
wms.xml -of WMS
gdal_translate \
-projwin 524136.39 5229915.17 527111.89 5226499.96 \
-projwin_srs EPSG:32610 \
-outsize 2500 0 \
wms.xml fails.tif
gdal_translate \
-projwin 517947.80 5235658.96 528189.82 5224344.74 \
-outsize 2500 0 \
wms.xml works.tif
Can anyone explain what's going on here and (most likely!) what I'm doing
wrong?
Thank you very much,
carl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210820/cb1dd4e3/attachment.html>
