[gdal-dev] Puzzled about gdal_translate return all white image...
Even Rouault
even.rouault at spatialys.com
Sat Aug 21 00:33:12 PDT 2021
Nothing wrong from your side, but the second command probably selects a
higher zoom level that has blank data given the configuration/data
available on the server side.
Le 21/08/2021 à 03:36, Carl Godkin a écrit :
> Hi,
> I'm very puzzled about why gdal_translate (v. 3.3.1) returns an
> all-white image when I select a smaller area than with a working case
> with a larger area.
> These two command lines are exactly the same except that the failing
> case has a smaller area:
> gdal_translate
> "https://basemap.nationalmap.gov:443/arcgis/services/USGSImageryTopo/MapServer/WmsServer?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=0&SRS=EPSG:4326&BBOX=-179.999989,-89.000000,179.999988,89.000000
> <https://basemap.nationalmap.gov:443/arcgis/services/USGSImageryTopo/MapServer/WmsServer?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=0&SRS=EPSG:4326&BBOX=-179.999989,-89.000000,179.999988,89.000000>"
> wms.xml -of WMS
> gdal_translate \
> -projwin 524136.39 5229915.17 527111.89 5226499.96 \
> -projwin_srs EPSG:32610 \
> -outsize 2500 0 \
> wms.xml fails.tif
> gdal_translate \
> -projwin 517947.80 5235658.96 528189.82 5224344.74 \
> -outsize 2500 0 \
> wms.xml works.tif
> Can anyone explain what's going on here and (most likely!) what I'm
> doing wrong?
> Thank you very much,
> carl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210821/976a6c99/attachment.html>
