[gdal-dev] On Internal PROJ When Building
Even Rouault
even.rouault at spatialys.com
Thu Aug 26 08:35:05 PDT 2021
Patrick,
I guess this is at least relevant for the ubuntu-full config that uses
libspatialite from the distro. This libspatialite must link against proj
6.3.1 from the Ubuntu 20.04 distro, whereas the GDAL we build will link
against the PROJ built in the image, so without that trick, crashes
would happen.
Even
Le 26/08/2021 à 17:21, Patrick Young a écrit :
> Hi,
> I was curious how relevant building an internal PROJ library is these
> days as described in this note
> https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev
> <https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev>
> I noticed GDAL's docker builds still do this. Are there some common
> dependencies that still use the older PROJ?
> Many thanks!
> Patrick
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210826/d656c88e/attachment.html>
