[gdal-dev] On Internal PROJ When Building
Even Rouault
even.rouault at spatialys.com
Thu Aug 26 08:43:23 PDT 2021
Actually looking at the wiki page, I've just updated it since it would
not have worked if the system PROJ is >= 6.0. The update consists in
adding -DPROJ_INTERNAL_CPP_NAMESPACE to CXXFLAGS when building PROJ so
that C++ symbols of the "internal" proj don't clash with the ones of the
system PROJ (that was Docker build recipees already did)
Le 26/08/2021 à 17:35, Even Rouault a écrit :
> Patrick,
> I guess this is at least relevant for the ubuntu-full config that uses
> libspatialite from the distro. This libspatialite must link against
> proj 6.3.1 from the Ubuntu 20.04 distro, whereas the GDAL we build
> will link against the PROJ built in the image, so without that trick,
> crashes would happen.
> Even
> Le 26/08/2021 à 17:21, Patrick Young a écrit :
>> Hi,
>> I was curious how relevant building an internal PROJ library is these
>> days as described in this note
>> https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev
>> <https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev>
>> I noticed GDAL's docker builds still do this. Are there some common
>> dependencies that still use the older PROJ?
>> Many thanks!
>> Patrick
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210826/fe6fcbc7/attachment.html>
