[gdal-dev] WFS Vector Layer Improvement
Even Rouault even.rouault at spatialys.com
Sun Aug 29 06:51:30 PDT 2021
David,
Per the standard (at least I checked in WFS 2.0), typename/typenames is
not a standardized query parameter for GetCapabilities. Are you
referring to some servers that would accept it as an extension ?
Even
Le 29/08/2021 à 08:06, aharon david a écrit :
> Hi,
> I want to suggest an  improvement in WFS Vector Layer.
> my suggestion is just to remove the lines 839 and 840:
>  osURL = CPLURLAddKVP(osURL, "TYPENAME", nullptr);
>  osURL = CPLURLAddKVP(osURL, "TYPENAMES", nullptr);
> in file: "gdal-3.3.1\ogr\ogrsf_frmts\wfs\ogrwfsdatasource.cpp".
> The big advantage is that the GetCapabilitiy Response will be minimal
> and contain info only
> for the layers that are set in the tag - TYPENAME in case it is placed
> in the pszBaseURL.
> There is no disadvantage to this change.
> There is no change in the function behavior.
> THanks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210829/54a74e69/attachment.html>
