[gdal-dev] WFS Vector Layer Improvement
Even Rouault
even.rouault at spatialys.com
Sun Aug 29 07:59:12 PDT 2021
(Adding back the list)
you can see in the following URL that typename\typenames are exist in
the WFS2 schema examples:
> http://schemas.opengis.net/wfs/2.0/examples/KVP/kvp.txt
> <http://schemas.opengis.net/wfs/2.0/examples/KVP/kvp.txt>
In those examples, Typename is just for GetFeature and
DescribeFeatureType, not GetCapabilities
> anyway, it is the standard of servers less than WFS 2.0 by sure.
Not in WFS 1.1 as far as I can see in
http://docs.opengeospatial.org/is/04-094r1/04-094r1.html#88
Even
> בתאריך יום א׳, 29 באוג׳ 2021 ב-16:51 מאת Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>:
> David,
> Per the standard (at least I checked in WFS 2.0),
> typename/typenames is not a standardized query parameter for
> GetCapabilities. Are you referring to some servers that would
> accept it as an extension ?
> Even
> Le 29/08/2021 à 08:06, aharon david a écrit :
>> Hi,
>> I want to suggest an improvement in WFS Vector Layer.
>> my suggestion is just to remove the lines 839 and 840:
>> osURL = CPLURLAddKVP(osURL, "TYPENAME", nullptr);
>> osURL = CPLURLAddKVP(osURL, "TYPENAMES", nullptr);
>> in file: "gdal-3.3.1\ogr\ogrsf_frmts\wfs\ogrwfsdatasource.cpp".
>> The big advantage is that the GetCapabilitiy Response will be
>> minimal and contain info only
>> for the layers that are set in the tag - TYPENAME in case it is
>> placed in the pszBaseURL.
>> There is no disadvantage to this change.
>> There is no change in the function behavior.
>> THanks.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210829/a05aeead/attachment.html>
