[gdal-dev] WFS Vector Layer Improvement
Even Rouault
even.rouault at spatialys.com
Sun Aug 29 11:10:36 PDT 2021
(Adding back the list again, please "Answer all")
Le 29/08/2021 à 19:59, aharon david a écrit :
> Ok, you right. But what about to add it as an extention? Why to remove
> it by force?
To avoid emitting confusing requests.
> As far as i can see in the code, other arbitary extenetions are
> permitted, why not to permit also this one?
This would only make sense if there were popular servers to implement
such an extension.
> בתאריך יום א׳, 29 באוג׳ 2021, 17:59, מאת Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>:
> (Adding back the list)
> you can see in the following URL that typename\typenames are exist
> in the WFS2 schema examples:
>> http://schemas.opengis.net/wfs/2.0/examples/KVP/kvp.txt
>> <http://schemas.opengis.net/wfs/2.0/examples/KVP/kvp.txt>
> In those examples, Typename is just for GetFeature and
> DescribeFeatureType, not GetCapabilities
>> anyway, it is the standard of servers less than WFS 2.0 by sure.
> Not in WFS 1.1 as far as I can see in
> http://docs.opengeospatial.org/is/04-094r1/04-094r1.html#88
> <http://docs.opengeospatial.org/is/04-094r1/04-094r1.html#88>
> Even
>> בתאריך יום א׳, 29 באוג׳ 2021 ב-16:51 מאת Even Rouault
>> David,
>> Per the standard (at least I checked in WFS 2.0),
>> typename/typenames is not a standardized query parameter for
>> GetCapabilities. Are you referring to some servers that would
>> accept it as an extension ?
>> Even
>> Le 29/08/2021 à 08:06, aharon david a écrit :
>>> Hi,
>>> I want to suggest an improvement in WFS Vector Layer.
>>> my suggestion is just to remove the lines 839 and 840:
>>> osURL = CPLURLAddKVP(osURL, "TYPENAME", nullptr);
>>> osURL = CPLURLAddKVP(osURL, "TYPENAMES", nullptr);
>>> in file: "gdal-3.3.1\ogr\ogrsf_frmts\wfs\ogrwfsdatasource.cpp".
>>> The big advantage is that the GetCapabilitiy Response will
>>> be minimal and contain info only
>>> for the layers that are set in the tag - TYPENAME in case it
>>> is placed in the pszBaseURL.
>>> There is no disadvantage to this change.
>>> There is no change in the function behavior.
>>> THanks.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
>> http://www.spatialys.com <http://www.spatialys.com>
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210829/86866c0e/attachment-0001.html>
