[gdal-dev] Help with OGDI vector driver usage
Even Rouault even.rouault at spatialys.com
Thu Dec 2 03:00:37 PST 2021
Le 02/12/2021 à 05:18, Carl Godkin a écrit :
> Hi,
> I've got some data that is in VPF (Vector Product Format) format and
> it appears that the OGDI vector should be able to consume it.
> I have GDAL 3.4.0 (the OSGeo4W build) and cannot figure out how to
> even run "ogrinfo" on the data set.
> From this page (https://gdal.org/drivers/vector/ogdi.html
> <https://gdal.org/drivers/vector/ogdi.html>), it appears that the
> syntax should be
> ogrinfo
> gltp:[//<hostname>]/<driver_name>/<dataset_name>:<layer_name>:<family>
> but in all of the examples, the "driver_name" is "vrf" so I tried that
> (as well as "vpf" out of desperation) but I'm on Windows so I'm
> puzzled about the exact syntax.
> My data is in d:\users\carl\vvod (which contains the dht and lat files).
> >ogrinfo gltp:/vrf/d/users/carl/vvod
try:
ogrinfo gltp:/vrf/d:/users/carl/vvod
> ERROR 1: OGDI DataSource Open Failed: Can't open CAT file, invalid VRF
> database
> database
> FAILURE:
> Unable to open datasource `gltp:/vrf/d/users/carl/vvod' with the
> following drivers.
> <long list of drivers>
> There are indeed "cat" files in every sub-directory of vvod, by the way.
> And I won't bore you with the 50 variations I tried.
> If anyone has experience with this driver and can provide some
> guidance, it would be very helpful.
> Thanks very much,
> carl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211202/c2493432/attachment.html>
