[gdal-dev] gdal installation error on MacOS (libpoppler.91.dylib)
Idan Miara idan at miara.com
Tue Dec 7 01:02:35 PST 2021
Hi all,
I'm trying to install gdal on MacOS Big Sur via conda.
For some reason it installs v3.0.2, even though v3.4.0 is available.
Also it doesn't run, and gives the following error:
~ gdalinfo --version
dyld: Library not loaded: @rpath/libpoppler.91.dylib
Thanks!
logs are below.
Kind regards,
Idan
conda install -c conda-forge gdal
Collecting package metadata (current_repodata.json): done
Solving environment: done
## Package Plan ##
  environment location: /Users/idan.miara/opt/miniconda3
  added / updated specs:
    - gdal
The following packages will be downloaded:
    package                    |            build
    boost-cpp-1.72.0           |       hdf9ef73_0        19.1 MB
 conda-forge
    bzip2-1.0.8                |       h0d85af4_4         155 KB
 conda-forge
    c-ares-1.18.1              |       h0d85af4_0         100 KB
 conda-forge
    ca-certificates-2021.10.8  |       h033912b_0         139 KB
 conda-forge
    cairo-1.16.0               |    hec6a9b0_1003         1.3 MB
 conda-forge
    certifi-2021.10.8          |   py39h6e9494a_1         145 KB
 conda-forge
    cfitsio-3.470              |       h01dc385_7         1.3 MB
 conda-forge
    conda-4.11.0               |   py39h6e9494a_0        16.9 MB
 conda-forge
    curl-7.78.0                |       h7bc2e8c_0         133 KB
    expat-2.4.1                |       he49afe7_0         143 KB
 conda-forge
    fontconfig-2.13.1          |    h10f422b_1005         271 KB
 conda-forge
    freetype-2.10.4            |       h4cff582_1         890 KB
 conda-forge
    freexl-1.0.6               |       h0d85af4_0          42 KB
 conda-forge
    gdal-3.0.2                 |   py39ha6ec53f_1         1.1 MB
    geos-3.8.0                 |       hb1e8313_0         815 KB
    geotiff-1.6.0              |       h02c1893_0         120 KB
    gettext-0.21.0             |       h7535e17_0         2.6 MB
    giflib-5.2.1               |       hbcb3906_2          71 KB
 conda-forge
    glib-2.69.1                |       hdf23fa2_0         2.7 MB
    hdf4-4.2.13                |       h39711bb_2         682 KB
    hdf5-1.10.6                |nompi_hc5d9132_1114         3.1 MB
 conda-forge
    icu-64.2                   |       h6de7cb9_1        12.3 MB
 conda-forge
    jbig-2.1                   |    h0d85af4_2003          42 KB
 conda-forge
    jpeg-9d                    |       hbcb3906_0         250 KB
 conda-forge
    json-c-0.13.1              |    h575e443_1002          66 KB
 conda-forge
    kealib-1.4.14              |       h31dd65d_2         156 KB
 conda-forge
    krb5-1.19.2                |       hcfbf3a7_0         1.3 MB
 conda-forge
    lerc-2.2.1                 |       h046ec9c_0         164 KB
 conda-forge
    libblas-3.9.0              |12_osx64_openblas          12 KB
 conda-forge
    libcblas-3.9.0             |12_osx64_openblas          12 KB
 conda-forge
    libcurl-7.78.0             |       hb8e4fae_0         311 KB
    libcxx-12.0.1              |       habf9029_0         1.1 MB
 conda-forge
    libdap4-3.19.1             |       h3d3e54a_0         1.1 MB
    libdeflate-1.7             |       h35c211d_5          67 KB
 conda-forge
    libedit-3.1.20191231       |       h0678c8f_2         103 KB
 conda-forge
    libev-4.33                 |       haf1e3a3_1          99 KB
 conda-forge
    libgdal-3.0.2              |       ha1444b2_1        10.4 MB
    libgfortran-5.0.0          |9_3_0_h6c81a4c_23          19 KB
 conda-forge
    libgfortran5-9.3.0         |      h6c81a4c_23         1.7 MB
 conda-forge
    libiconv-1.16              |       haf1e3a3_0         1.3 MB
 conda-forge
    libkml-1.3.0               |    h88bc94a_1012         473 KB
 conda-forge
    liblapack-3.9.0            |12_osx64_openblas          12 KB
 conda-forge
    libnetcdf-4.6.1            |       hfd9a460_4         782 KB
    libnghttp2-1.43.0          |       h6f36284_1         867 KB
 conda-forge
    libopenblas-0.3.18         |openmp_h3351f45_0         9.0 MB
 conda-forge
    libpng-1.6.37              |       h7cec526_2         313 KB
 conda-forge
    libpq-12.2                 |       h1b4eb34_1         2.0 MB
    libspatialite-4.3.0a       |       h5142b36_0         2.1 MB
    libssh2-1.10.0             |       h52ee1ee_2         221 KB
 conda-forge
    libtiff-4.3.0              |       h1167814_1         621 KB
 conda-forge
    libwebp-base-1.2.1         |       h0d85af4_0         692 KB
 conda-forge
    libxml2-2.9.10             |       h53d96d6_0         1.2 MB
 conda-forge
    llvm-openmp-12.0.1         |       hda6cdc1_1         287 KB
 conda-forge
    lz4-c-1.9.3                |       he49afe7_1         155 KB
 conda-forge
    numpy-1.21.4               |   py39h7eed0ac_0         5.8 MB
 conda-forge
    openjpeg-2.3.1             |       h6cbf5cd_3         373 KB
 conda-forge
    openssl-1.1.1l             |       h0d85af4_0         1.9 MB
 conda-forge
    pcre-8.45                  |       he49afe7_0         220 KB
 conda-forge
    pixman-0.38.0              |    h01d97ff_1003         611 KB
 conda-forge
    poppler-0.89.0             |       h9de36d4_1         1.6 MB
 conda-forge
    poppler-data-0.4.11        |       hd8ed1ab_0         3.6 MB
 conda-forge
    postgresql-12.2            |       h1b4eb34_1         3.3 MB
    proj-6.2.1                 |       h773a61f_0        10.0 MB
 conda-forge
    python_abi-3.9             |           2_cp39           4 KB
 conda-forge
    tiledb-2.3.4               |       h8370e7a_0         2.9 MB
 conda-forge
    xerces-c-3.2.3             |       h8f8adb3_0         1.5 MB
 conda-forge
    zstd-1.5.0                 |       h582d3a0_0         583 KB
 conda-forge
                                           Total:       133.2 MB
The following NEW packages will be INSTALLED:
  boost-cpp          conda-forge/osx-64::boost-cpp-1.72.0-hdf9ef73_0
  bzip2              conda-forge/osx-64::bzip2-1.0.8-h0d85af4_4
  c-ares             conda-forge/osx-64::c-ares-1.18.1-h0d85af4_0
  cairo              conda-forge/osx-64::cairo-1.16.0-hec6a9b0_1003
  cfitsio            conda-forge/osx-64::cfitsio-3.470-h01dc385_7
  curl               pkgs/main/osx-64::curl-7.78.0-h7bc2e8c_0
  expat              conda-forge/osx-64::expat-2.4.1-he49afe7_0
  fontconfig         conda-forge/osx-64::fontconfig-2.13.1-h10f422b_1005
  freetype           conda-forge/osx-64::freetype-2.10.4-h4cff582_1
  freexl             conda-forge/osx-64::freexl-1.0.6-h0d85af4_0
  gdal               pkgs/main/osx-64::gdal-3.0.2-py39ha6ec53f_1
  geos               pkgs/main/osx-64::geos-3.8.0-hb1e8313_0
  geotiff            pkgs/main/osx-64::geotiff-1.6.0-h02c1893_0
  gettext            pkgs/main/osx-64::gettext-0.21.0-h7535e17_0
  giflib             conda-forge/osx-64::giflib-5.2.1-hbcb3906_2
  glib               pkgs/main/osx-64::glib-2.69.1-hdf23fa2_0
  hdf4               pkgs/main/osx-64::hdf4-4.2.13-h39711bb_2
  hdf5               conda-forge/osx-64::hdf5-1.10.6-nompi_hc5d9132_1114
  icu                conda-forge/osx-64::icu-64.2-h6de7cb9_1
  jbig               conda-forge/osx-64::jbig-2.1-h0d85af4_2003
  jpeg               conda-forge/osx-64::jpeg-9d-hbcb3906_0
  json-c             conda-forge/osx-64::json-c-0.13.1-h575e443_1002
  kealib             conda-forge/osx-64::kealib-1.4.14-h31dd65d_2
  krb5               conda-forge/osx-64::krb5-1.19.2-hcfbf3a7_0
  lerc               conda-forge/osx-64::lerc-2.2.1-h046ec9c_0
  libblas            conda-forge/osx-64::libblas-3.9.0-12_osx64_openblas
  libcblas           conda-forge/osx-64::libcblas-3.9.0-12_osx64_openblas
  libcurl            pkgs/main/osx-64::libcurl-7.78.0-hb8e4fae_0
  libdap4            pkgs/main/osx-64::libdap4-3.19.1-h3d3e54a_0
  libdeflate         conda-forge/osx-64::libdeflate-1.7-h35c211d_5
  libedit            conda-forge/osx-64::libedit-3.1.20191231-h0678c8f_2
  libev              conda-forge/osx-64::libev-4.33-haf1e3a3_1
  libgdal            pkgs/main/osx-64::libgdal-3.0.2-ha1444b2_1
  libgfortran        conda-forge/osx-64::libgfortran-5.0.0-9_3_0_h6c81a4c_23
  libgfortran5       conda-forge/osx-64::libgfortran5-9.3.0-h6c81a4c_23
  libiconv           conda-forge/osx-64::libiconv-1.16-haf1e3a3_0
  libkml             conda-forge/osx-64::libkml-1.3.0-h88bc94a_1012
  liblapack          conda-forge/osx-64::liblapack-3.9.0-12_osx64_openblas
  libnetcdf          pkgs/main/osx-64::libnetcdf-4.6.1-hfd9a460_4
  libnghttp2         conda-forge/osx-64::libnghttp2-1.43.0-h6f36284_1
  libopenblas
 conda-forge/osx-64::libopenblas-0.3.18-openmp_h3351f45_0
  libpng             conda-forge/osx-64::libpng-1.6.37-h7cec526_2
  libpq              pkgs/main/osx-64::libpq-12.2-h1b4eb34_1
  libspatialite      pkgs/main/osx-64::libspatialite-4.3.0a-h5142b36_0
  libssh2            conda-forge/osx-64::libssh2-1.10.0-h52ee1ee_2
  libtiff            conda-forge/osx-64::libtiff-4.3.0-h1167814_1
  libwebp-base       conda-forge/osx-64::libwebp-base-1.2.1-h0d85af4_0
  libxml2            conda-forge/osx-64::libxml2-2.9.10-h53d96d6_0
  llvm-openmp        conda-forge/osx-64::llvm-openmp-12.0.1-hda6cdc1_1
  lz4-c              conda-forge/osx-64::lz4-c-1.9.3-he49afe7_1
  numpy              conda-forge/osx-64::numpy-1.21.4-py39h7eed0ac_0
  openjpeg           conda-forge/osx-64::openjpeg-2.3.1-h6cbf5cd_3
  pcre               conda-forge/osx-64::pcre-8.45-he49afe7_0
  pixman             conda-forge/osx-64::pixman-0.38.0-h01d97ff_1003
  poppler            conda-forge/osx-64::poppler-0.89.0-h9de36d4_1
  poppler-data       conda-forge/noarch::poppler-data-0.4.11-hd8ed1ab_0
  postgresql         pkgs/main/osx-64::postgresql-12.2-h1b4eb34_1
  proj               conda-forge/osx-64::proj-6.2.1-h773a61f_0
  python_abi         conda-forge/osx-64::python_abi-3.9-2_cp39
  tiledb             conda-forge/osx-64::tiledb-2.3.4-h8370e7a_0
  xerces-c           conda-forge/osx-64::xerces-c-3.2.3-h8f8adb3_0
  zstd               conda-forge/osx-64::zstd-1.5.0-h582d3a0_0
The following packages will be UPDATED:
  ca-certificates    pkgs/main::ca-certificates-2021.7.5-h~ -->
conda-forge::ca-certificates-2021.10.8-h033912b_0
  certifi            pkgs/main::certifi-2021.5.30-py39hecd~ -->
conda-forge::certifi-2021.10.8-py39h6e9494a_1
  conda              pkgs/main::conda-4.10.3-py39hecd8cb5_0 -->
conda-forge::conda-4.11.0-py39h6e9494a_0
  libcxx                         pkgs/main::libcxx-10.0.0-1 -->
conda-forge::libcxx-12.0.1-habf9029_0
  openssl              pkgs/main::openssl-1.1.1k-h9ed2024_0 -->
conda-forge::openssl-1.1.1l-h0d85af4_0
Proceed ([y]/n)? y
Downloading and Extracting Packages
bzip2-1.0.8          | 155 KB    |
| 100%
fontconfig-2.13.1    | 271 KB    |
| 100%
krb5-1.19.2          | 1.3 MB    |
| 100%
gdal-3.0.2           | 1.1 MB    |
| 100%
freetype-2.10.4      | 890 KB    |
| 100%
hdf5-1.10.6          | 3.1 MB    |
| 100%
proj-6.2.1           | 10.0 MB   |
| 100%
libblas-3.9.0        | 12 KB     |
| 100%
lerc-2.2.1           | 164 KB    |
| 100%
libgfortran-5.0.0    | 19 KB     |
| 100%
lz4-c-1.9.3          | 155 KB    |
| 100%
libiconv-1.16        | 1.3 MB    |
| 100%
icu-64.2             | 12.3 MB   |
| 100%
libedit-3.1.20191231 | 103 KB    |
| 100%
libxml2-2.9.10       | 1.2 MB    |
| 100%
python_abi-3.9       | 4 KB      |
| 100%
numpy-1.21.4         | 5.8 MB    |
| 100%
conda-4.11.0         | 16.9 MB   |
| 100%
ca-certificates-2021 | 139 KB    |
| 100%
poppler-0.89.0       | 1.6 MB    |
| 100%
liblapack-3.9.0      | 12 KB     |
| 100%
expat-2.4.1          | 143 KB    |
| 100%
boost-cpp-1.72.0     | 19.1 MB   |
| 100%
glib-2.69.1          | 2.7 MB    |
| 100%
libgdal-3.0.2        | 10.4 MB   |
| 100%
libspatialite-4.3.0a | 2.1 MB    |
| 100%
libnetcdf-4.6.1      | 782 KB    |
| 100%
openssl-1.1.1l       | 1.9 MB    |
| 100%
hdf4-4.2.13          | 682 KB    |
| 100%
libcurl-7.78.0       | 311 KB    |
| 100%
jpeg-9d              | 250 KB    |
| 100%
openjpeg-2.3.1       | 373 KB    |
| 100%
libwebp-base-1.2.1   | 692 KB    |
| 100%
c-ares-1.18.1        | 100 KB    |
| 100%
libdap4-3.19.1       | 1.1 MB    |
| 100%
libpng-1.6.37        | 313 KB    |
| 100%
xerces-c-3.2.3       | 1.5 MB    |
| 100%
libdeflate-1.7       | 67 KB     |
| 100%
geos-3.8.0           | 815 KB    |
| 100%
giflib-5.2.1         | 71 KB     |
| 100%
libgfortran5-9.3.0   | 1.7 MB    |
| 100%
libssh2-1.10.0       | 221 KB    |
| 100%
libcxx-12.0.1        | 1.1 MB    |
| 100%
libopenblas-0.3.18   | 9.0 MB    |
| 100%
geotiff-1.6.0        | 120 KB    |
| 100%
libnghttp2-1.43.0    | 867 KB    |
| 100%
zstd-1.5.0           | 583 KB    |
| 100%
libtiff-4.3.0        | 621 KB    |
| 100%
libkml-1.3.0         | 473 KB    |
| 100%
libcblas-3.9.0       | 12 KB     |
| 100%
tiledb-2.3.4         | 2.9 MB    |
| 100%
llvm-openmp-12.0.1   | 287 KB    |
| 100%
gettext-0.21.0       | 2.6 MB    |
| 100%
curl-7.78.0          | 133 KB    |
| 100%
pixman-0.38.0        | 611 KB    |
| 100%
json-c-0.13.1        | 66 KB     |
| 100%
cairo-1.16.0         | 1.3 MB    |
| 100%
postgresql-12.2      | 3.3 MB    |
| 100%
jbig-2.1             | 42 KB     |
| 100%
certifi-2021.10.8    | 145 KB    |
| 100%
libev-4.33           | 99 KB     |
| 100%
libpq-12.2           | 2.0 MB    |
| 100%
poppler-data-0.4.11  | 3.6 MB    |
| 100%
cfitsio-3.470        | 1.3 MB    |
| 100%
freexl-1.0.6         | 42 KB     |
| 100%
pcre-8.45            | 220 KB    |
| 100%
kealib-1.4.14        | 156 KB    |
| 100%
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
(base) ➜  ~ gdalinfo --version
  Referenced from: /Users/idan.miara/opt/miniconda3/lib/libgdal.26.dylib
  Reason: image not found
[1]    76584 abort      gdalinfo --version
(base) ➜  ~
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211207/5ec1d9f1/attachment-0001.html>
