[gdal-dev] gdal installation error on MacOS (libpoppler.91.dylib)
Daniel Scheffler daniel.scheffler at gfz-potsdam.de
Tue Dec 7 03:33:16 PST 2021
If you installed into the base environment, you should rollback it to
the last clean revision. Use /conda list --revisions/ to see which
revision number you need to use. Then use /conda install --revision N/
(where N is the revision number).
You should also make sure that your conda package resolver is up-to-date
before creating a new environment for gdal.  Otherwise, it might happen
that conda installs an old gdal version. To update it, run /conda update
conda/ or /conda update --all/ in your base environment. Note hat you
may have to add /-c conda-forge/ to avoid mixing up packages coming from
the /main /channel with those from the /conda-forge/ channel.
Am 07.12.2021 um 12:15 schrieb Paul Harwood:
> Results like that are usually caused because there is something
> already in the conda environment that is causing a conflict and I
> notice that it is installing into  /Users/idan.miara/opt/miniconda3
> which would usually mean you have installed into the "base" conda
> environment - which is not usually the best idea.
> If you try ...
> conda create --name gdaltest
> conda activate gdaltest
> conda install -c conda-forge gdal
> {noteing that the name "gdaltest" in the first and second lines could
> be any name for a conda environment that is not already in use}
> ... I am reasonably sure it will work.
> Then you just need to use the "gdaltest" environment when you want to
> use conda.
> On Tue, 7 Dec 2021 at 09:03, Idan Miara <idan at miara.com> wrote:
>     Hi all,
>     I'm trying to install gdal on MacOS Big Sur via conda.
>     For some reason it installs v3.0.2, even though v3.4.0 is available.
>     Also it doesn't run, and gives the following error:
>     ~ gdalinfo --version
>     dyld: Library not loaded: @rpath/libpoppler.91.dylib
>     Thanks!
>     logs are below.
>     Kind regards,
>     Idan
>     Collecting package metadata (current_repodata.json): done
>     Solving environment: done
>     ## Package Plan ##
>       environment location: /Users/idan.miara/opt/miniconda3
>       added / updated specs:
>         - gdal
>     The following packages will be downloaded:
>         package                    |            build
>         boost-cpp-1.72.0           |       hdf9ef73_0  19.1 MB
>      conda-forge
>         bzip2-1.0.8                |       h0d85af4_4 155 KB  conda-forge
>         c-ares-1.18.1              |       h0d85af4_0 100 KB  conda-forge
>         ca-certificates-2021.10.8  |       h033912b_0 139 KB  conda-forge
>         cairo-1.16.0               |    hec6a9b0_1003 1.3 MB  conda-forge
>         certifi-2021.10.8          |   py39h6e9494a_1 145 KB  conda-forge
>         cfitsio-3.470              |       h01dc385_7 1.3 MB  conda-forge
>         conda-4.11.0               |   py39h6e9494a_0  16.9 MB
>      conda-forge
>         curl-7.78.0                |       h7bc2e8c_0 133 KB
>         expat-2.4.1                |       he49afe7_0 143 KB  conda-forge
>         fontconfig-2.13.1          |    h10f422b_1005 271 KB  conda-forge
>         freetype-2.10.4            |       h4cff582_1 890 KB  conda-forge
>         freexl-1.0.6               |       h0d85af4_0  42 KB  conda-forge
>         gdal-3.0.2                 |   py39ha6ec53f_1 1.1 MB
>         geos-3.8.0                 |       hb1e8313_0 815 KB
>         geotiff-1.6.0              |       h02c1893_0 120 KB
>         gettext-0.21.0             |       h7535e17_0 2.6 MB
>         giflib-5.2.1               |       hbcb3906_2  71 KB  conda-forge
>         glib-2.69.1                |       hdf23fa2_0 2.7 MB
>         hdf4-4.2.13                |       h39711bb_2 682 KB
>         hdf5-1.10.6                |nompi_hc5d9132_1114   3.1 MB
>      conda-forge
>         icu-64.2                   |       h6de7cb9_1  12.3 MB
>      conda-forge
>         jbig-2.1                   |    h0d85af4_2003  42 KB  conda-forge
>         jpeg-9d                    |       hbcb3906_0 250 KB  conda-forge
>         json-c-0.13.1              |    h575e443_1002  66 KB  conda-forge
>         kealib-1.4.14              |       h31dd65d_2 156 KB  conda-forge
>         krb5-1.19.2                |       hcfbf3a7_0 1.3 MB  conda-forge
>         lerc-2.2.1                 |       h046ec9c_0 164 KB  conda-forge
>         libblas-3.9.0              |12_osx64_openblas  12 KB  conda-forge
>         libcblas-3.9.0             |12_osx64_openblas  12 KB  conda-forge
>         libcurl-7.78.0             |       hb8e4fae_0 311 KB
>         libcxx-12.0.1              |       habf9029_0 1.1 MB  conda-forge
>         libdap4-3.19.1             |       h3d3e54a_0 1.1 MB
>         libdeflate-1.7             |       h35c211d_5  67 KB  conda-forge
>         libedit-3.1.20191231       |       h0678c8f_2 103 KB  conda-forge
>         libev-4.33                 |       haf1e3a3_1  99 KB  conda-forge
>         libgdal-3.0.2              |       ha1444b2_1  10.4 MB
>         libgfortran-5.0.0          |9_3_0_h6c81a4c_23  19 KB  conda-forge
>         libgfortran5-9.3.0         |      h6c81a4c_23 1.7 MB  conda-forge
>         libiconv-1.16              |       haf1e3a3_0 1.3 MB  conda-forge
>         libkml-1.3.0               |    h88bc94a_1012 473 KB  conda-forge
>         liblapack-3.9.0            |12_osx64_openblas  12 KB  conda-forge
>         libnetcdf-4.6.1            |       hfd9a460_4 782 KB
>         libnghttp2-1.43.0          |       h6f36284_1 867 KB  conda-forge
>         libopenblas-0.3.18         |openmp_h3351f45_0 9.0 MB  conda-forge
>         libpng-1.6.37              |       h7cec526_2 313 KB  conda-forge
>         libpq-12.2                 |       h1b4eb34_1 2.0 MB
>         libspatialite-4.3.0a       |       h5142b36_0 2.1 MB
>         libssh2-1.10.0             |       h52ee1ee_2 221 KB  conda-forge
>         libtiff-4.3.0              |       h1167814_1 621 KB  conda-forge
>         libwebp-base-1.2.1         |       h0d85af4_0 692 KB  conda-forge
>         libxml2-2.9.10             |       h53d96d6_0 1.2 MB  conda-forge
>         llvm-openmp-12.0.1         |       hda6cdc1_1 287 KB  conda-forge
>         lz4-c-1.9.3                |       he49afe7_1 155 KB  conda-forge
>         numpy-1.21.4               |   py39h7eed0ac_0 5.8 MB  conda-forge
>         openjpeg-2.3.1             |       h6cbf5cd_3 373 KB  conda-forge
>         openssl-1.1.1l             |       h0d85af4_0 1.9 MB  conda-forge
>         pcre-8.45                  |       he49afe7_0 220 KB  conda-forge
>         pixman-0.38.0              |    h01d97ff_1003 611 KB  conda-forge
>         poppler-0.89.0             |       h9de36d4_1 1.6 MB  conda-forge
>         poppler-data-0.4.11        |       hd8ed1ab_0 3.6 MB  conda-forge
>         postgresql-12.2            |       h1b4eb34_1 3.3 MB
>         proj-6.2.1                 |       h773a61f_0  10.0 MB
>      conda-forge
>         python_abi-3.9             |           2_cp39   4 KB  conda-forge
>         tiledb-2.3.4               |       h8370e7a_0 2.9 MB  conda-forge
>         xerces-c-3.2.3             |       h8f8adb3_0 1.5 MB  conda-forge
>         zstd-1.5.0                 |       h582d3a0_0 583 KB  conda-forge
>                                                Total: 133.2 MB
>     The following NEW packages will be INSTALLED:
>       boost-cpp  conda-forge/osx-64::boost-cpp-1.72.0-hdf9ef73_0
>       bzip2  conda-forge/osx-64::bzip2-1.0.8-h0d85af4_4
>       c-ares conda-forge/osx-64::c-ares-1.18.1-h0d85af4_0
>       cairo  conda-forge/osx-64::cairo-1.16.0-hec6a9b0_1003
>       cfitsio  conda-forge/osx-64::cfitsio-3.470-h01dc385_7
>       curl pkgs/main/osx-64::curl-7.78.0-h7bc2e8c_0
>       expat  conda-forge/osx-64::expat-2.4.1-he49afe7_0
>       fontconfig conda-forge/osx-64::fontconfig-2.13.1-h10f422b_1005
>       freetype conda-forge/osx-64::freetype-2.10.4-h4cff582_1
>       freexl conda-forge/osx-64::freexl-1.0.6-h0d85af4_0
>       gdal pkgs/main/osx-64::gdal-3.0.2-py39ha6ec53f_1
>       geos pkgs/main/osx-64::geos-3.8.0-hb1e8313_0
>       geotiff  pkgs/main/osx-64::geotiff-1.6.0-h02c1893_0
>       gettext  pkgs/main/osx-64::gettext-0.21.0-h7535e17_0
>       giflib conda-forge/osx-64::giflib-5.2.1-hbcb3906_2
>       glib pkgs/main/osx-64::glib-2.69.1-hdf23fa2_0
>       hdf4 pkgs/main/osx-64::hdf4-4.2.13-h39711bb_2
>       hdf5 conda-forge/osx-64::hdf5-1.10.6-nompi_hc5d9132_1114
>       icu  conda-forge/osx-64::icu-64.2-h6de7cb9_1
>       jbig conda-forge/osx-64::jbig-2.1-h0d85af4_2003
>       jpeg conda-forge/osx-64::jpeg-9d-hbcb3906_0
>       json-c conda-forge/osx-64::json-c-0.13.1-h575e443_1002
>       kealib conda-forge/osx-64::kealib-1.4.14-h31dd65d_2
>       krb5 conda-forge/osx-64::krb5-1.19.2-hcfbf3a7_0
>       lerc conda-forge/osx-64::lerc-2.2.1-h046ec9c_0
>       libblas  conda-forge/osx-64::libblas-3.9.0-12_osx64_openblas
>       libcblas conda-forge/osx-64::libcblas-3.9.0-12_osx64_openblas
>       libcurl  pkgs/main/osx-64::libcurl-7.78.0-hb8e4fae_0
>       libdap4  pkgs/main/osx-64::libdap4-3.19.1-h3d3e54a_0
>       libdeflate conda-forge/osx-64::libdeflate-1.7-h35c211d_5
>       libedit  conda-forge/osx-64::libedit-3.1.20191231-h0678c8f_2
>       libev  conda-forge/osx-64::libev-4.33-haf1e3a3_1
>       libgdal  pkgs/main/osx-64::libgdal-3.0.2-ha1444b2_1
>       libgfortran  conda-forge/osx-64::libgfortran-5.0.0-9_3_0_h6c81a4c_23
>       libgfortran5 conda-forge/osx-64::libgfortran5-9.3.0-h6c81a4c_23
>       libiconv conda-forge/osx-64::libiconv-1.16-haf1e3a3_0
>       libkml conda-forge/osx-64::libkml-1.3.0-h88bc94a_1012
>       liblapack  conda-forge/osx-64::liblapack-3.9.0-12_osx64_openblas
>       libnetcdf  pkgs/main/osx-64::libnetcdf-4.6.1-hfd9a460_4
>       libnghttp2 conda-forge/osx-64::libnghttp2-1.43.0-h6f36284_1
>       libopenblas
>      conda-forge/osx-64::libopenblas-0.3.18-openmp_h3351f45_0
>       libpng conda-forge/osx-64::libpng-1.6.37-h7cec526_2
>       libpq  pkgs/main/osx-64::libpq-12.2-h1b4eb34_1
>       libspatialite  pkgs/main/osx-64::libspatialite-4.3.0a-h5142b36_0
>       libssh2  conda-forge/osx-64::libssh2-1.10.0-h52ee1ee_2
>       libtiff  conda-forge/osx-64::libtiff-4.3.0-h1167814_1
>       libwebp-base conda-forge/osx-64::libwebp-base-1.2.1-h0d85af4_0
>       libxml2  conda-forge/osx-64::libxml2-2.9.10-h53d96d6_0
>       llvm-openmp  conda-forge/osx-64::llvm-openmp-12.0.1-hda6cdc1_1
>       lz4-c  conda-forge/osx-64::lz4-c-1.9.3-he49afe7_1
>       numpy  conda-forge/osx-64::numpy-1.21.4-py39h7eed0ac_0
>       openjpeg conda-forge/osx-64::openjpeg-2.3.1-h6cbf5cd_3
>       pcre conda-forge/osx-64::pcre-8.45-he49afe7_0
>       pixman conda-forge/osx-64::pixman-0.38.0-h01d97ff_1003
>       poppler  conda-forge/osx-64::poppler-0.89.0-h9de36d4_1
>       poppler-data conda-forge/noarch::poppler-data-0.4.11-hd8ed1ab_0
>       postgresql pkgs/main/osx-64::postgresql-12.2-h1b4eb34_1
>       proj conda-forge/osx-64::proj-6.2.1-h773a61f_0
>       python_abi conda-forge/osx-64::python_abi-3.9-2_cp39
>       tiledb conda-forge/osx-64::tiledb-2.3.4-h8370e7a_0
>       xerces-c conda-forge/osx-64::xerces-c-3.2.3-h8f8adb3_0
>       zstd conda-forge/osx-64::zstd-1.5.0-h582d3a0_0
>     The following packages will be UPDATED:
>       ca-certificates  pkgs/main::ca-certificates-2021.7.5-h~ -->
>     conda-forge::ca-certificates-2021.10.8-h033912b_0
>       certifi  pkgs/main::certifi-2021.5.30-py39hecd~ -->
>     conda-forge::certifi-2021.10.8-py39h6e9494a_1
>       conda  pkgs/main::conda-4.10.3-py39hecd8cb5_0 -->
>     conda-forge::conda-4.11.0-py39h6e9494a_0
>       libcxx pkgs/main::libcxx-10.0.0-1 -->
>     conda-forge::libcxx-12.0.1-habf9029_0
>       openssl  pkgs/main::openssl-1.1.1k-h9ed2024_0 -->
>     conda-forge::openssl-1.1.1l-h0d85af4_0
>     Proceed ([y]/n)? y
>     Downloading and Extracting Packages
>     bzip2-1.0.8          | 155 KB    |
>     | 100%
>     fontconfig-2.13.1    | 271 KB    |
>     | 100%
>     krb5-1.19.2          | 1.3 MB    |
>     | 100%
>     gdal-3.0.2           | 1.1 MB    |
>     | 100%
>     freetype-2.10.4      | 890 KB    |
>     | 100%
>     hdf5-1.10.6          | 3.1 MB    |
>     | 100%
>     proj-6.2.1           | 10.0 MB   |
>     | 100%
>     libblas-3.9.0        | 12 KB     |
>     | 100%
>     lerc-2.2.1           | 164 KB    |
>     | 100%
>     libgfortran-5.0.0    | 19 KB     |
>     | 100%
>     lz4-c-1.9.3          | 155 KB    |
>     | 100%
>     libiconv-1.16        | 1.3 MB    |
>     | 100%
>     icu-64.2             | 12.3 MB   |
>     | 100%
>     libedit-3.1.20191231 | 103 KB    |
>     | 100%
>     libxml2-2.9.10       | 1.2 MB    |
>     | 100%
>     python_abi-3.9       | 4 KB      |
>     | 100%
>     numpy-1.21.4         | 5.8 MB    |
>     | 100%
>     conda-4.11.0         | 16.9 MB   |
>     | 100%
>     ca-certificates-2021 | 139 KB    |
>     | 100%
>     poppler-0.89.0       | 1.6 MB    |
>     | 100%
>     liblapack-3.9.0      | 12 KB     |
>     | 100%
>     expat-2.4.1          | 143 KB    |
>     | 100%
>     boost-cpp-1.72.0     | 19.1 MB   |
>     | 100%
>     glib-2.69.1          | 2.7 MB    |
>     | 100%
>     libgdal-3.0.2        | 10.4 MB   |
>     | 100%
>     libspatialite-4.3.0a | 2.1 MB    |
>     | 100%
>     libnetcdf-4.6.1      | 782 KB    |
>     | 100%
>     openssl-1.1.1l       | 1.9 MB    |
>     | 100%
>     hdf4-4.2.13          | 682 KB    |
>     | 100%
>     libcurl-7.78.0       | 311 KB    |
>     | 100%
>     jpeg-9d              | 250 KB    |
>     | 100%
>     openjpeg-2.3.1       | 373 KB    |
>     | 100%
>     libwebp-base-1.2.1   | 692 KB    |
>     | 100%
>     c-ares-1.18.1        | 100 KB    |
>     | 100%
>     libdap4-3.19.1       | 1.1 MB    |
>     | 100%
>     libpng-1.6.37        | 313 KB    |
>     | 100%
>     xerces-c-3.2.3       | 1.5 MB    |
>     | 100%
>     libdeflate-1.7       | 67 KB     |
>     | 100%
>     geos-3.8.0           | 815 KB    |
>     | 100%
>     giflib-5.2.1         | 71 KB     |
>     | 100%
>     libgfortran5-9.3.0   | 1.7 MB    |
>     | 100%
>     libssh2-1.10.0       | 221 KB    |
>     | 100%
>     libcxx-12.0.1        | 1.1 MB    |
>     | 100%
>     libopenblas-0.3.18   | 9.0 MB    |
>     | 100%
>     geotiff-1.6.0        | 120 KB    |
>     | 100%
>     libnghttp2-1.43.0    | 867 KB    |
>     | 100%
>     zstd-1.5.0           | 583 KB    |
>     | 100%
>     libtiff-4.3.0        | 621 KB    |
>     | 100%
>     libkml-1.3.0         | 473 KB    |
>     | 100%
>     libcblas-3.9.0       | 12 KB     |
>     | 100%
>     tiledb-2.3.4         | 2.9 MB    |
>     | 100%
>     llvm-openmp-12.0.1   | 287 KB    |
>     | 100%
>     gettext-0.21.0       | 2.6 MB    |
>     | 100%
>     curl-7.78.0          | 133 KB    |
>     | 100%
>     pixman-0.38.0        | 611 KB    |
>     | 100%
>     json-c-0.13.1        | 66 KB     |
>     | 100%
>     cairo-1.16.0         | 1.3 MB    |
>     | 100%
>     postgresql-12.2      | 3.3 MB    |
>     | 100%
>     jbig-2.1             | 42 KB     |
>     | 100%
>     certifi-2021.10.8    | 145 KB    |
>     | 100%
>     libev-4.33           | 99 KB     |
>     | 100%
>     libpq-12.2           | 2.0 MB    |
>     | 100%
>     poppler-data-0.4.11  | 3.6 MB    |
>     | 100%
>     cfitsio-3.470        | 1.3 MB    |
>     | 100%
>     freexl-1.0.6         | 42 KB     |
>     | 100%
>     pcre-8.45            | 220 KB    |
>     | 100%
>     kealib-1.4.14        | 156 KB    |
>     | 100%
>     Preparing transaction: done
>     Verifying transaction: done
>     Executing transaction: done
>     (base) ➜  ~ gdalinfo --version
>       Referenced from:
>     /Users/idan.miara/opt/miniconda3/lib/libgdal.26.dylib
>       Reason: image not found
>     [1]    76584 abort      gdalinfo --version
>     (base) ➜  ~
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
M.Sc. Geogr. Daniel Scheffler
Helmholtz Centre Potsdam
GFZ German Research Centre For Geosciences
Department 1 - Geodesy and Remote Sensing
Section 1.4  - Remote Sensing
Telegrafenberg, 14473 Potsdam, Germany
Phone:  +49 (0)331/288-1198
e-mail:daniel.scheffler at gfz-potsdam.de
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211207/4e81e1d2/attachment-0001.html>
