[gdal-dev] Access window out of range error with standard utils
    Matt.Wilkie at yukon.ca
    Wed Dec  8 09:35:16 PST 2021
Hello,
Why is gdal off by one for the access window? I'm using standard utilities, no custom code. This is only happening (so far) on one file out of dozens.
$ gdal_translate -co compress=zstd -co predictor=yes -co level=17 ^
 -co bigtiff=yes -of cog INFILE.rgb-nir.vrt OUTFILE.tif
Input file size is 31918, 34252
0.ERROR 5: Access window out of range in RasterIO().  Requested
(0,0) of size 250x268 on raster of 249x267.
This is one step of a process where I'm taking two 3-band jpeg-in-geotiff images, defining a nodata mask, and creating a final 4-band cloud geotiff. Preceding steps to this one are:
gdal_translate -b 1 RGB.tif  b-red.vrt
gdal_translate -b 2 RGB.tif  b-grn.vrt
gdal_translate -b 3 RGB.tif  b-blu.vrt
gdal_translate -b 1 432.tif  b-nir.vrt
gdalbuildvrt -separate INFILE.rgb-nir.vrt ^
  b-red.vrt b-grn.vrt b-blu.vrt b-nir.vrt
gdal_translate INFILE.rgb-nir.vrt xx-to-mask.tif
nearblack -setmask xx-to-mask.tif
move xx-mask.tif.msk INFILE.rgb-nir.vrt.msk
del xx-mask.tif
gdal_translate INFILE.rgb-nir.vrt OUTFILE.tif
(Edited for legibility, options used are left out)
Gdalinfo reports the size of each image are the same:
$ findstr "Size" *.gdal-info
RGB.b-blu.vrt.gdal-info:Size is 31918, 34252
RGB.b-blu.vrt.gdal-info:Pixel Size = (1.500000000000000,-1.500000000000000)
RGB.b-grn.vrt.gdal-info:Size is 31918, 34252
RGB.b-grn.vrt.gdal-info:Pixel Size = (1.500000000000000,-1.500000000000000)
RGB.b-red.vrt.gdal-info:Size is 31918, 34252
RGB.b-red.vrt.gdal-info:Pixel Size = (1.500000000000000,-1.500000000000000)
432.b-nir.vrt.gdal-info:Size is 31918, 34252
432.b-nir.vrt.gdal-info:Pixel Size = (1.500000000000000,-1.500000000000000)
INFILE.rgb-nir.vrt.gdal-info:Size is 31918, 34252
INFILE.rgb-nir.vrt.gdal-info:Pixel Size = (1.500000000000000,-1.500000000000000)
INFILE.rgb-nir.vrt.msk.gdal-info:Size is 31918, 34252
The source VRT and gdalinfo reports are attached.
GDAL 3.3.2, released 2021/09/01 via Qgis 3.22 on Windows 10.
Matt Wilkie
Geomatics Developer & Administrator
Environment | Technology, Innovation and Mapping
T 867-667-8133 | Yukon.ca<http://yukon.ca/>
Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/65ed7dbd/attachment-0001.html>
Type: application/x-zip-compressed
Desc: access-window-err-inputs.zip
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/65ed7dbd/attachment-0001.bin>
