[gdal-dev] ogrinfo XML (AIXM)
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Dec 9 05:56:46 PST 2021
Please try the unsubscribe link at the bottom of the mailing list info page https://lists.osgeo.org/mailman/listinfo/gdal-dev.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Baker (US), Anthony W
Lähetetty: torstai 9. joulukuuta 2021 14.02
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] ogrinfo XML (AIXM)
Please remove me from this email distribution.
Thank you
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of paul.malm at lfv.se<mailto:paul.malm at lfv.se>
Sent: Thursday, December 09, 2021 3:52 AM
To: even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] ogrinfo XML (AIXM)
EXT email: be mindful of links/attachments.
Is this the correct syntax:
C:\>ogrinfo GMLAS:c:\Temp\data\Mydata.GML
I get the error:
ERROR 3: Cannot resolve http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
FAILURE:
Unable to open datasource `GMLAS:c:\Temp\eaddata\EADdata.GML' with the following drivers.
  -> BAG
  -> JP2ECW
  -> FITS
  -> netCDF
  -> PDF
  -> AmigoCloud
  -> FileGDB
  -> ESRIC
  -> PCIDSK
  -> PDS4
  -> VICAR
  -> JP2OpenJPEG
  -> MBTiles
  -> EEDA
  -> OGCAPI
  -> DB2ODBC
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> LVBAG
  -> OGR_SDTS
  -> S57
  -> DGN
  -> OGR_VRT
  -> REC
  -> Memory
  -> BNA
  -> CSV
  -> NAS
  -> GML
  -> GPX
  -> LIBKML
  -> KML
  -> GeoJSON
  -> GeoJSONSeq
  -> ESRIJSON
  -> TopoJSON
  -> Interlis 1
  -> Interlis 2
  -> OGR_GMT
  -> GPKG
  -> SQLite
  -> ODBC
  -> WAsP
  -> PGeo
  -> MSSQLSpatial
  -> OGR_OGDI
  -> PostgreSQL
  -> MySQL
  -> OpenFileGDB
  -> XPlane
  -> DXF
  -> CAD
  -> FlatGeobuf
  -> Geoconcept
  -> GeoRSS
  -> GPSTrackMaker
  -> VFK
  -> PGDUMP
  -> OSM
  -> GPSBabel
  -> SUA
  -> OpenAir
  -> OGR_PDS
  -> WFS
  -> OAPIF
  -> HTF
  -> AeronavFAA
  -> Geomedia
  -> EDIGEO
  -> SVG
  -> CouchDB
  -> Cloudant
  -> Idrisi
  -> ARCGEN
  -> SEGUKOOA
  -> SEGY
  -> ODS
  -> XLSX
  -> Elasticsearch
  -> Walk
  -> Carto
  -> SXF
  -> Selafin
  -> JML
  -> PLSCENES
  -> CSW
  -> VDV
  -> GMLAS
  -> MVT
  -> NGW
  -> MapML
  -> TIGER
  -> AVCBin
  -> AVCE00
  -> HTTP
Kind regards,
Paul
Från: gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> För Even Rouault
Skickat: den 8 december 2021 14:17
Till: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Ämne: Re: [gdal-dev] ogrinfo XML (AIXM)
Klicka bara på länkar och öppna bilagor om du litar på avsändaren och vet att innehållet är säkert.
Paul,
the GML driver can open some formulation of AIXM, but probably not all.
You may also try the generic GMLAS driver: https://gdal.org/drivers/vector/gmlas.html<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=uz6vvUD3oCT_jv_J5c_6KFuW0bs7EadIzr6OyxIasmJB9f0PvrKackVIBaRsFK-0stBeq1jraWibIe0x4V8n-DqK_LxdtuDwLz4StmNGea8b709nnGHKo6LHjY6UtNxFRoL3LvpEKfLl3hjdjYHY9syToDuM2pO38ed50RsrAYxQmOxUUkTk4lJsAL576_C7ixRLkb6v0gGEBz19nHYgwz5tF4VetmM5wctrqTBPzgnGA3Vrxc60mpoDN6zujvfITr8U2NsMq8ucDdCh1a-zyQsms4KWk3XQaSgMr54DgjA>
Even
Le 08/12/2021 à 14:06, paul.malm at lfv.se<mailto:paul.malm at lfv.se> a écrit :
I'm trying to read a XML (AIXM) file. But ogrinfo says it can't be read with either  KML, KMZ or GML installed drivers (among other formats).
Is there anything I must do, the GML, KML, KMZ drivers are there. I'm working in Windows 10.
Kind Regards,
Paul
    [1_LFV_svensk_96]
  Paul Malm
  Operations / AIM Flyginfo SE
  Direkt  08-797 70 23  Mobil 070-860 11 15
   Besöks- och postadress
   LFV Flyginfo SE
   Af Pontins väg 6
   115 21 STOCKHOLM
   Tänk på miljön innan du skriver ut detta e-postmeddelande.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=8cQdqlhVp6efzQPPPMP2SSoz1twQoc-Brn1LHEqN6oLcHdKYGbwOMLaS1ud2-c3K2wJz_BjWpsvl_sFiClF25Mkjf26TUJ0lngn57KfU5_1pvRYlSzF-TSRVK7FmkE2-lN-FzsJrpQ_uALYChCE8uKG44TrZXaSjXrm6_g5glOMqqxyXu2se8hTXiVV0TcMyWT0PM6bRtDidilS2e5dRAkGN4FniHqO-r279Xxlxc_0BS-JA8pt3peQIVgFzxvXtOViQeKZo18om84eSdbwiswYDunnqEYA2qSjoRj7hSPISZXTR0sM0VLk1J7OS85xk>
http://www.spatialys.com<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=YwQqpD2eaPwcv6LDZBcVDWMnjpiEULCacsUNFprErGwVLGI8CsHK3CFLDUm1C9iguPEKghMKrE1S38rRIq9iX0dMmZ8_TZG28jNN05jm0SSkJg9nYMej-gdcJAdasx1eJ5jQflEf3TPJBK-Ny18ruljafZ8yd5uCbB3JPK79JbPtzHZFMCGNPSMCCnAxtihQnz7g-LFEjGKX5k1jAJ3zg-I1V5yEWedzV9cAzxofReXeozuQNOdAjImHBEhMrH-SC5OU3ZABTJyNhCfym4wWfg>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/5dd5e7a9/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/5dd5e7a9/attachment-0001.jpg>
