[gdal-dev] Access window out of range error with standard utils
Even Rouault even.rouault at spatialys.com
Wed Dec 8 10:35:11 PST 2021
No better with your .msk file. I don't think it is a usage issue.
You could likely create reproducers using gdal_create that will create a
blank file with same dimension, band count, spatial information, etc.
gdal_create -if input.tif output.tif -co sparse_ok=yes -co tiled=yes
Le 08/12/2021 à 19:24, Matt.Wilkie at yukon.ca a écrit :
> Thanks Even,
> I’ve narrowed it down to the mask file. When I move it out of the way
> gdal_translate completes without error. Perhaps my optimization step
> of using nearblack on only the infrared band instead of all 4 is at fault?
> I agree it’s hard to troubleshoot when the examples are not
> self-contained! I wish I were free to share the source images. I can
> share the .msk file though: https://paste.c-net.org/StrapsMaple
> (First time using this service. I know nothing about it excepting it
> was the 1^st result when searching for “binary pastebin”)
> -Matt//
> *From:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *On Behalf Of *Even
> Rouault
> *Sent:* December 8, 2021 11:08 AM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Access window out of range error with
> standard utils
> Matt,
> this is likely a rounding bug somewhere, but I couldn't reproduce with
> what you provided (with GDAL master and 3.3.2 on Linux). I had to fix
> a few hardcoded paths in the VRTs and create
> SPOT7_FiftyMileCkSixtyMileR_321_150cm_19Jun2015_utm7.tif and
> SPOT7_FiftyMileCkSixtyMileR_432_150cm_19Jun2015_utm7.tif with
> gdal_create SPOT7_FiftyMileCkSixtyMileR_321_150cm_19Jun2015_utm7.tif
> -outsize 31918 34252 -bands 4 -co tiled=yes -co sparse_ok=yes
> gdaladdo SPOT7_FiftyMileCkSixtyMileR_321_150cm_19Jun2015_utm7.tif
> --config SPARSE_OK_OVERVIEW YES       # SPARSE_OK_OVERVIEW only taken
> into account with GDAL master
> I also create a .vrt.msk file with
> gdal_create
> SPOT7_FiftyMileCkSixtyMileR_321_150cm_19Jun2015_utm7.vrt.msk -outsize
> 31912 34252 -co sparse_ok=yes -mo INTERNAL_MASK_FLAGS_1=2 -of gtiff
> gdaladdo SPOT7_FiftyMileCkSixtyMileR_321_150cm_19Jun2015_utm7.vrt.msk
> I may have missed something. It would help if your reproducer was self
> contained.
> Even
> Le 08/12/2021 à 18:35, Matt.Wilkie at yukon.ca
> <mailto:Matt.Wilkie at yukon.ca> a écrit :
>     Hello,
>     Why is gdal off by one for the access window? I’m using standard
>     utilities, no custom code. This is only happening (so far) on one
>     file out of dozens.
>     $ gdal_translate -co compress=zstd -co predictor=yes -co level=17 ^
>      -co bigtiff=yes -of cog INFILE.rgb-nir.vrt OUTFILE.tif
>     Input file size is 31918, 34252
>     0.ERROR 5: Access window out of range in RasterIO().  Requested
>     (0,0) of size 250x268 on raster of 249x267.
>     This is one step of a process where I’m taking two 3-band
>     jpeg-in-geotiff images, defining a nodata mask, and creating a
>     final 4-band cloud geotiff. Preceding steps to this one are:
>     gdal_translate -b 1 RGB.tif  b-red.vrt
>     gdal_translate -b 2 RGB.tif  b-grn.vrt
>     gdal_translate -b 3 RGB.tif  b-blu.vrt
>     gdal_translate -b 1 432.tif  b-nir.vrt
>     gdalbuildvrt -separate INFILE.rgb-nir.vrt ^
>     b-red.vrt b-grn.vrt b-blu.vrt b-nir.vrt
>     gdal_translate INFILE.rgb-nir.vrt xx-to-mask.tif
>     nearblack –setmask xx-to-mask.tif
>     move xx-mask.tif.msk INFILE.rgb-nir.vrt.msk
>     del xx-mask.tif
>     gdal_translate INFILE.rgb-nir.vrt OUTFILE.tif
>     (Edited for legibility, options used are left out)
>     Gdalinfo reports the size of each image are the same:
>     $ findstr "Size" *.gdal-info
>     RGB.b-blu.vrt.gdal-info:Size is 31918, 34252
>     RGB.b-blu.vrt.gdal-info:Pixel Size =
>     (1.500000000000000,-1.500000000000000)
>     RGB.b-grn.vrt.gdal-info:Size is 31918, 34252
>     RGB.b-grn.vrt.gdal-info:Pixel Size =
>     RGB.b-red.vrt.gdal-info:Size is 31918, 34252
>     RGB.b-red.vrt.gdal-info:Pixel Size =
>     432.b-nir.vrt.gdal-info:Size is 31918, 34252
>     432.b-nir.vrt.gdal-info:Pixel Size =
>     INFILE.rgb-nir.vrt.gdal-info:Size is 31918, 34252
>     INFILE.rgb-nir.vrt.gdal-info:Pixel Size =
>     INFILE.rgb-nir.vrt.msk.gdal-info:Size is 31918, 34252
>     The source VRT and gdalinfo reports are attached.
>     GDAL 3.3.2, released 2021/09/01 via Qgis 3.22 on Windows 10.
>     *Matt Wilkie*
>     Geomatics Developer & Administrator
>     Environment | Technology, Innovation and Mapping
>     T 867-667-8133 | _Yukon.ca <http://yukon.ca/>_
>     /Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away./
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com  <https://imsva91-ctp.trendmicro.com:443/wis/clicktime/v1/query?url=http%3a%2f%2fwww.spatialys.com&umid=B685D7CA-D2A6-5E05-A200-E0AFE3B43C72&auth=c132af8ee7c9d1278d61a701569070a095ce962e-45f9e6e44e2899ec331fad264f0287e272c8edd7>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/eb554ca7/attachment.html>
