[gdal-dev] Access window out of range error with standard utils
Even Rouault
even.rouault at spatialys.com
Thu Dec 9 12:27:59 PST 2021
fixed per https://github.com/OSGeo/gdal/pull/4965
you can likely workaround the issue by running gdaladdo on the .vrt.msk
prior to COGification
Even
Le 08/12/2021 à 18:35, Matt.Wilkie at yukon.ca a écrit :
> Hello,
> Why is gdal off by one for the access window? I’m using standard
> utilities, no custom code. This is only happening (so far) on one file
> out of dozens.
> $ gdal_translate -co compress=zstd -co predictor=yes -co level=17 ^
> -co bigtiff=yes -of cog INFILE.rgb-nir.vrt OUTFILE.tif
> Input file size is 31918, 34252
> 0.ERROR 5: Access window out of range in RasterIO(). Requested
> (0,0) of size 250x268 on raster of 249x267.
> This is one step of a process where I’m taking two 3-band
> jpeg-in-geotiff images, defining a nodata mask, and creating a final
> 4-band cloud geotiff. Preceding steps to this one are:
> gdal_translate -b 1 RGB.tif b-red.vrt
> gdal_translate -b 2 RGB.tif b-grn.vrt
> gdal_translate -b 3 RGB.tif b-blu.vrt
> gdal_translate -b 1 432.tif b-nir.vrt
> gdalbuildvrt -separate INFILE.rgb-nir.vrt ^
> b-red.vrt b-grn.vrt b-blu.vrt b-nir.vrt
> gdal_translate INFILE.rgb-nir.vrt xx-to-mask.tif
> nearblack –setmask xx-to-mask.tif
> move xx-mask.tif.msk INFILE.rgb-nir.vrt.msk
> del xx-mask.tif
> gdal_translate INFILE.rgb-nir.vrt OUTFILE.tif
> (Edited for legibility, options used are left out)
> Gdalinfo reports the size of each image are the same:
> $ findstr "Size" *.gdal-info
> RGB.b-blu.vrt.gdal-info:Size is 31918, 34252
> RGB.b-blu.vrt.gdal-info:Pixel Size =
> (1.500000000000000,-1.500000000000000)
> RGB.b-grn.vrt.gdal-info:Size is 31918, 34252
> RGB.b-grn.vrt.gdal-info:Pixel Size =
> RGB.b-red.vrt.gdal-info:Size is 31918, 34252
> RGB.b-red.vrt.gdal-info:Pixel Size =
> 432.b-nir.vrt.gdal-info:Size is 31918, 34252
> 432.b-nir.vrt.gdal-info:Pixel Size =
> INFILE.rgb-nir.vrt.gdal-info:Size is 31918, 34252
> INFILE.rgb-nir.vrt.gdal-info:Pixel Size =
> INFILE.rgb-nir.vrt.msk.gdal-info:Size is 31918, 34252
> The source VRT and gdalinfo reports are attached.
> GDAL 3.3.2, released 2021/09/01 via Qgis 3.22 on Windows 10.
> *Matt Wilkie*
> Geomatics Developer & Administrator
> Environment | Technology, Innovation and Mapping
> T 867-667-8133 | _Yukon.ca <http://yukon.ca/>_
> /Hours: 08:30-16:30, Mon-Wed: Office, Thu: Remote, Fri: Away./
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/667bb0c8/attachment-0001.html>
