[gdal-dev] ogrinfo XML (AIXM)
paul.malm at lfv.se
paul.malm at lfv.se
Thu Dec 9 00:51:40 PST 2021
Is this the correct syntax:
C:\>ogrinfo GMLAS:c:\Temp\data\Mydata.GML
I get the error:
ERROR 3: Cannot resolve http://www.aixm.aero/schema/4.5/AIXM-Snapshot.xsd
FAILURE:
Unable to open datasource `GMLAS:c:\Temp\eaddata\EADdata.GML' with the following drivers.
-> BAG
-> JP2ECW
-> FITS
-> netCDF
-> PDF
-> AmigoCloud
-> FileGDB
-> ESRIC
-> PCIDSK
-> PDS4
-> VICAR
-> JP2OpenJPEG
-> MBTiles
-> EEDA
-> OGCAPI
-> DB2ODBC
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> LVBAG
-> OGR_SDTS
-> S57
-> DGN
-> OGR_VRT
-> REC
-> Memory
-> BNA
-> CSV
-> NAS
-> GML
-> GPX
-> LIBKML
-> KML
-> GeoJSON
-> GeoJSONSeq
-> ESRIJSON
-> TopoJSON
-> Interlis 1
-> Interlis 2
-> OGR_GMT
-> GPKG
-> SQLite
-> ODBC
-> WAsP
-> PGeo
-> MSSQLSpatial
-> OGR_OGDI
-> PostgreSQL
-> MySQL
-> OpenFileGDB
-> XPlane
-> DXF
-> CAD
-> FlatGeobuf
-> Geoconcept
-> GeoRSS
-> GPSTrackMaker
-> VFK
-> PGDUMP
-> OSM
-> GPSBabel
-> SUA
-> OpenAir
-> OGR_PDS
-> WFS
-> OAPIF
-> HTF
-> AeronavFAA
-> Geomedia
-> EDIGEO
-> SVG
-> CouchDB
-> Cloudant
-> Idrisi
-> ARCGEN
-> SEGUKOOA
-> SEGY
-> ODS
-> XLSX
-> Elasticsearch
-> Walk
-> Carto
-> SXF
-> Selafin
-> JML
-> PLSCENES
-> CSW
-> VDV
-> GMLAS
-> MVT
-> NGW
-> MapML
-> TIGER
-> AVCBin
-> AVCE00
-> HTTP
Kind regards,
Paul
Från: gdal-dev <gdal-dev-bounces at lists.osgeo.org> För Even Rouault
Skickat: den 8 december 2021 14:17
Till: gdal-dev at lists.osgeo.org
Ämne: Re: [gdal-dev] ogrinfo XML (AIXM)
Klicka bara på länkar och öppna bilagor om du litar på avsändaren och vet att innehållet är säkert.
Paul,
the GML driver can open some formulation of AIXM, but probably not all.
You may also try the generic GMLAS driver: https://gdal.org/drivers/vector/gmlas.html<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=uz6vvUD3oCT_jv_J5c_6KFuW0bs7EadIzr6OyxIasmJB9f0PvrKackVIBaRsFK-0stBeq1jraWibIe0x4V8n-DqK_LxdtuDwLz4StmNGea8b709nnGHKo6LHjY6UtNxFRoL3LvpEKfLl3hjdjYHY9syToDuM2pO38ed50RsrAYxQmOxUUkTk4lJsAL576_C7ixRLkb6v0gGEBz19nHYgwz5tF4VetmM5wctrqTBPzgnGA3Vrxc60mpoDN6zujvfITr8U2NsMq8ucDdCh1a-zyQsms4KWk3XQaSgMr54DgjA>
Even
Le 08/12/2021 à 14:06, paul.malm at lfv.se<mailto:paul.malm at lfv.se> a écrit :
I'm trying to read a XML (AIXM) file. But ogrinfo says it can't be read with either KML, KMZ or GML installed drivers (among other formats).
Is there anything I must do, the GML, KML, KMZ drivers are there. I'm working in Windows 10.
Kind Regards,
Paul
[1_LFV_svensk_96]
Paul Malm
Operations / AIM Flyginfo SE
Direkt 08-797 70 23 Mobil 070-860 11 15
Besöks- och postadress
LFV Flyginfo SE
Af Pontins väg 6
115 21 STOCKHOLM
Tänk på miljön innan du skriver ut detta e-postmeddelande.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=8cQdqlhVp6efzQPPPMP2SSoz1twQoc-Brn1LHEqN6oLcHdKYGbwOMLaS1ud2-c3K2wJz_BjWpsvl_sFiClF25Mkjf26TUJ0lngn57KfU5_1pvRYlSzF-TSRVK7FmkE2-lN-FzsJrpQ_uALYChCE8uKG44TrZXaSjXrm6_g5glOMqqxyXu2se8hTXiVV0TcMyWT0PM6bRtDidilS2e5dRAkGN4FniHqO-r279Xxlxc_0BS-JA8pt3peQIVgFzxvXtOViQeKZo18om84eSdbwiswYDunnqEYA2qSjoRj7hSPISZXTR0sM0VLk1J7OS85xk>
http://www.spatialys.com<https://url11b.mailanyone.net/v1/?m=1muwp2-00020I-3x&i=57e1b682&c=YwQqpD2eaPwcv6LDZBcVDWMnjpiEULCacsUNFprErGwVLGI8CsHK3CFLDUm1C9iguPEKghMKrE1S38rRIq9iX0dMmZ8_TZG28jNN05jm0SSkJg9nYMej-gdcJAdasx1eJ5jQflEf3TPJBK-Ny18ruljafZ8yd5uCbB3JPK79JbPtzHZFMCGNPSMCCnAxtihQnz7g-LFEjGKX5k1jAJ3zg-I1V5yEWedzV9cAzxofReXeozuQNOdAjImHBEhMrH-SC5OU3ZABTJyNhCfym4wWfg>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/c76ec0aa/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/c76ec0aa/attachment-0001.jpg>
