[gdal-dev] ogrinfo XML (AIXM)
Andreas Oxenstierna
andreas.oxenstierna at t-kartor.com
Wed Dec 8 06:04:05 PST 2021
Paul, AIXM is far too complex to be read completely by ogr, at least two years ago.
You need some of the specific AIXM readers that is in the market.
Best Regards
Andreas Oxenstierna
T-Kartor Geospatial AB
Olof Mohlins väg 12 Kristianstad
mobile: +46 733 206831
mailto: andreas.oxenstierna at t-kartor.com<mailto:andreas.oxenstierna at t-kartor.com>
www.t-kartor.com<http://www.t-kartor.com>
On 8 Dec 2021, 14:17 +0100, Even Rouault <even.rouault at spatialys.com>, wrote:
Paul,
the GML driver can open some formulation of AIXM, but probably not all.
You may also try the generic GMLAS driver: https://gdal.org/drivers/vector/gmlas.html
Even
Le 08/12/2021 à 14:06, paul.malm at lfv.se<mailto:paul.malm at lfv.se> a écrit :
I’m trying to read a XML (AIXM) file. But ogrinfo says it can’t be read with either KML, KMZ or GML installed drivers (among other formats).
Is there anything I must do, the GML, KML, KMZ drivers are there. I’m working in Windows 10.
Kind Regards,
Paul
[1_LFV_svensk_96]
Paul Malm
Operations / AIM Flyginfo SE
Direkt 08-797 70 23 Mobil 070-860 11 15
Besöks- och postadress
LFV Flyginfo SE
Af Pontins väg 6
115 21 STOCKHOLM
Tänk på miljön innan du skriver ut detta e-postmeddelande.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/97849591/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/97849591/attachment-0001.jpg>
