[gdal-dev] ogrinfo XML (AIXM)
Even Rouault
even.rouault at spatialys.com
Wed Dec 8 05:16:59 PST 2021
Paul,
the GML driver can open some formulation of AIXM, but probably not all.
You may also try the generic GMLAS driver:
https://gdal.org/drivers/vector/gmlas.html
Even
Le 08/12/2021 à 14:06, paul.malm at lfv.se a écrit :
> Hi,
> I’m trying to read a XML (AIXM) file. But ogrinfo says it can’t be
> read with either KML, KMZ or GML installed drivers (among other formats).
> Is there anything I must do, the GML, KML, KMZ drivers are there. I’m
> working in Windows 10.
> Kind Regards,
> Paul
> 1_LFV_svensk_96
> Paul Malm
> Operations / AIM Flyginfo SE
> Direkt 08-797 70 23 Mobil 070-860 11 15
> paul.malm at lfv.se
> Besöks- och postadress
> LFV Flyginfo SE
> Af Pontins väg 6
> 115 21 STOCKHOLM
> Tänk på miljön innan du skriver ut detta e-postmeddelande.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/1b1bfd59/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211208/1b1bfd59/attachment.jpg>
