[gdal-dev] ogrinfo XML (AIXM)
paul.malm at lfv.se
paul.malm at lfv.se
Thu Dec 9 02:42:42 PST 2021
Tried with the downloaded file:
https://github.com/aixm/donlon/blob/master/EA_EADD_OBS_DS_AREA_2_3_4_FULL_20191205.xml
And the result is:
C:\>ogrinfo GMLAS:c:\Temp\eaddata\EA_EADD_OBS_DS_AREA_2_3_4_FULL_20191205.xml --debug on
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_BAG.dll using GDALRegister_BAG.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_FITS.dll using GDALRegister_FITS.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_GMT.dll using GDALRegister_GMT.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF4.dll using GDALRegister_HDF4.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF4Image.dll using GDALRegister_HDF4Image.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF5.dll using GDALRegister_HDF5.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_HDF5Image.dll using GDALRegister_HDF5Image.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_KEA.dll using GDALRegister_KEA.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_MG4Lidar.dll using GDALRegister_MG4Lidar.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_MrSID.dll using GDALRegister_MrSID.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_netCDF.dll using GDALRegister_netCDF.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\gdal_PDF.dll using GDALRegister_PDF.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins\ogr_AmigoCloud.dll using RegisterOGRAmigoCloud.
GDAL: Auto register C:\Program Files\Gdal_321\bin\gdal\plugins-external\ogr_FileGDB.dll using RegisterOGRFileGDB.
OGR: XMLPlatformUtils::Initialize()
GMLAS: XSD cache directory: C:\Users\anpaumal\.gdal\gmlas_xsd_cache
ERROR 1: No schema locations found when analyzing data file: XSD open option must be provided
OGR: XMLPlatformUtils::Terminate()
FAILURE:
Unable to open datasource `GMLAS:c:\Temp\eaddata\EA_EADD_OBS_DS_AREA_2_3_4_FULL_20191205.xml' with the following drivers.
-> BAG
-> JP2ECW
-> FITS ...
Från: gdal-dev <gdal-dev-bounces at lists.osgeo.org> För Rahkonen Jukka (MML)
Skickat: den 9 december 2021 10:56
Till: 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
Ämne: Re: [gdal-dev] ogrinfo XML (AIXM)
Klicka bara på länkar och öppna bilagor om du litar på avsändaren och vet att innehållet är säkert.
Re-sending to the list without old discussion because the mail body grew too large and was rejected.
I do not have not much experience about GMLAS but I made a test with this file https://github.com/aixm/donlon/blob/master/EA_EADD_OBS_DS_AREA_2_3_4_FULL_20191205.xml<https://url11b.mailanyone.net/v1/?m=1mvG9j-0005WB-4U&i=57e1b682&c=o93b5pDX4vaaGiFe-4fCRTt-Emwy84b-5wbMMklRliBx7zChVW06bSZUCSgtXAXzHzcSm5FK62ZvbAxFqEuAyx_QkIzcYyfmAp8SxJJl5CJQvo5KAqIttqVB_C_QNC9PsfQ-SW1n1YQL9hSfF-4308rIwP1OTpBL6R3gIPw8v71eE09ioGNnDUhlc0G248AcYku_7bmGvHqE-Bym3r52P6k6Np0fegE0yEAnUo_JgkD1IpsB96IXvDpDuZt4JYDOFXuSJG0qa3ZOXEsCIKmByOkbwQQ2PtWH0y1Gr3J1JMfShDYp8U2VoSrWrd--vNy1hz7GH3XeOTD6u47c6KQ8NB1khlulVISG3hyvspOP84A>
and GDAL GMLAS found 1655 layers with "ogrinfo GMLAS:aixtest.xml" without editing the file so it seems that GDAL can follow http redirections and there is some other problem with your XML. Try the test files from GitHub and try to find out what is different in your GML.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211209/d194e696/attachment.html>
