[gdal-dev] Transforming Raster Points from GeoTIFF with GCPs
Simon Eves simon.eves at omnisci.com
Fri Dec 10 11:20:54 PST 2021
Aha! That's the bit I hadn't found. Thank you! :)
On Fri, Dec 10, 2021 at 10:38 AM Yann-Sebastien Tremblay-Johnston <
yanns.tremblay at gmail.com> wrote:
> Simon,
> See the Transformer API, in particular
> https://gdal.org/api/gdal_alg.html?highlight=transformer#_CPPv419GDALTransformerFunc
> (or gdal.Transformer in Python).
> Sebastien
> On Fri, Dec 10, 2021 at 10:24 AM Simon Eves <simon.eves at omnisci.com>
> wrote:
>> So we have a GeoTiFF of Sentinel-1 imagery which `gdalinfo` reports as
>> having a GCP projection with 210 points, which we'd (perhaps naively?!)
>> like to import directly, transforming to WGS84 on the fly.
>> Obviously a simple OGRSpatialReference/OGRCoordinateTransformation
>> transform isn't going to do anything, so I assume we have to do the GCP
>> transform manually.
>> I found the GCPCoordinateTransformation class and other supporting code
>> in ogr2ogr_lib.cpp as used by gdaltransform, which seems to do what we
>> need, but of course it's not in the core GDAL library so we can't "just use
>> it".
>> Before embarking on lifting out that code to implement an on-the-fly
>> transformer in our system, I just wanted to make sure I wasn't missing any
>> functionality elsewhere that would make it easier.
>> It may also be more efficient to just kick off a gdalwarp to pre-convert
>> the file so we can just import it with no transformation required, but that
>> seems ugly unless it's gonna be WAY more efficient?
>> Thanks,
>> Simon
>> <http://www.omnisci.com/>
>> Simon Eves
>> Senior Graphics Engineer, Rendering Group
>> 100 Montgomery St (5th Floor), San Francisco, CA 94104, USA
>> Email: simon.eves at omnisci.com | Cell:  +1 (415) 902-1996
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Simon Eves
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20211210/72cf555f/attachment-0001.html>
